Detroit won't start
Discussion in 'Ask An Owner Operator' started by Yankee02, Mar 31, 2019.
  1. Yankee02
    Yankee02 Bobtail Member
    10
    Mar 31, 2019
    2007 Detroit won't start after sitting for three months
  3. xsetra
    xsetra Road Train Member
    5,198
    7,149
    Aug 21, 2011
    What does it do or not do.
    Dead batteries?
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    More definitive details please.
    Won’t start:
    - no electricity
    - clicks starter won’t turn
    - engine turns over won’t fire
    - etc
  5. blairandgretchen
    13,964
    76,789
    Dec 9, 2011
    South west Missouri
    Fuel filters changed and full?
  6. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Check the fuses to the ECM.
    I glide 47 Thanks this.
  7. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Jumper cables,hooked up and charging for at least half hour, key on, if no check engine lights on dash, check fuse for ecm,otherwise crank it up, use either sparingly, if needed.
  8. Yankee02
    10
    Mar 31, 2019
  9. Yankee02
    10
    Mar 31, 2019
    Sorry all plenty of juice cranks great will only run on ether ran fine when turned off about 3 months ago
    Rideandrepair Thanks this.
  10. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Sounds like ecm fuse located on hot cable near battery, small blade type. 10 or 15 amp? Or a bad ground on the frame. If that’s the problem , usually the yellow/ red check engine lights won’t illuminate on dash with key in on position.
  11. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Otherwise if ecm is getting power, and no codes are thrown. Maybe a bad timing sensor or 2. Maybe just a bad connection on a timing sensor.
    HopeOverMope Thanks this.
