Diesel exhaust fluid filter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Feb 17, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Where is it located and how often does it need to be cleaned/replaced?
  3. ChicagoJohn
    ChicagoJohn Road Train Member
    2,390
    2,755
    Jan 14, 2016
    Chicago
    What year and model? DEF or just DPF?
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    Its 2013 kw T660 with Cummins isx15 def fluid.
  5. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    There is one in the tank located on the end of the header for the tank. There is another one located on bottom of the def pump. They are both replace filters, not clean and put back in as far as I know. The big circle with lots of fins on it, that is the nut for it. I only changed them once I got a fault for them. The one in the tank is not fun to change. I would not change the one in the tank until after you change the one on the pump and only if you get fault codes for a restriction in the system would I change it. The one on the bottom of the pump is not bad to change at all. You will get DEF everywhere when you change that one.
    mitmaks Thanks this.
  6. ChicagoJohn
    2,390
    2,755
    Jan 14, 2016
    Chicago
    Sorry, not familiar with Cummins. I've been told by numerous people the key to Detroit's is changing the dpf filter every 200,000-250,000, cleaning to doc at that time and changing the site filter every year. Maybe Cummins is same principle?
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    ^^^Not the right way.^^^^
  8. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    Why isn't that the right way? It is nice that you say that but not say what is not right about it. He never specified what filter he was needing to look at. The SCR is not a filter, it is a catalyst.
  9. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    You state that you only replace the DEF filter when you get a fault.
    That isn't right.
    One should replace that filter yearly.
  10. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    I've actually never seen a service interval for that stated. Even in the owners manual for the trucks.
    That wasn't so hard was it to actually type out a response to the statement stating that instead of just saying that it was right now was it?
  11. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Sometimes you read something and want to respond but you do not have time for a long explanation.
