Disc/drums
Discussion in 'Ask An Owner Operator' started by abyliks, Aug 1, 2024.
  1. abyliks
    abyliks Road Train Member
    4,138
    9,743
    May 2, 2010
    ludlow MA
    So I’m going through the order sheet of a new fridge, basically just doing minor changes to an already O/O spec, and they have disc brakes on the order form, been a while since I had discs on anything but the last time I had disc on a tractor and drum on a trailer I remember the trailer would lock up easier under a harder (but not panic) brake situation, don’t know if they are different crack pressures or if it’s just the equipment I was driving, just curious if anyone had the same experience or if maybe I just wasn’t used to the set up.
    cliff notes, anyone have a tractor with drum brakes and a trailer with disc and have any problems?
    Oxbow and NightWind Thank this.
  3. wichris
    wichris Road Train Member
    4,507
    9,281
    Jan 17, 2011
    Have O/O's with drum that pull my disc trailers. No problem, same as the opposite way. Just have to be careful on long, steep down grades. The drums heat far more than the discs.
    wore out, Oxbow, shanman and 6 others Thank this.
  4. Dave1837
    Dave1837 Road Train Member
    1,402
    4,349
    Nov 16, 2019
    Pennsylvania
    I drove a tractor with drums and a trailer with discs, never had an issue. Also driven vise versa and have had the trailer tires skid a few times. It's easy to correct once you learn how much pressure to put on the pedal
    Oxbow, Siinman and abyliks Thank this.
  5. abyliks
    4,138
    9,743
    May 2, 2010
    ludlow MA
    Discs were definitely impressive, I just wanted to make sure I wasn’t going to be causing a different set of issues
    I’m one to always drop an extra half a gear and just stay off the brakes completely if possible any way
    Oxbow and Siinman Thank this.
  6. wichris
    4,507
    9,281
    Jan 17, 2011
    If the trailers a spread, make sure it's a 4s not 2s abs
    Oxbow, dosgatos, abyliks and 1 other person Thank this.
  7. Siinman
    Siinman Road Train Member
    5,531
    14,230
    Mar 5, 2017
    Kansas City, MO.
    Have Disc on front of tractor and drums on back of tractor with Disc Brakes on Dry Van. Never had any issues on my feet up. I did however have an issue with drums on my old truck and rented trailer after installing new pads on trailer. Should be good to go.
    Vitkouski Thanks this.
  8. Vitkouski
    Vitkouski Light Load Member
    199
    279
    Mar 6, 2016
    Disc are way more better. Wondering home much effort FMCSA making to govern the speed instead to mandate to make all new trucks and trailers with disc brakes only. How much effort government make to forbidden idling and lover the emissions instead to mandate equip all new sleeper trucks with bunk heaters....
    AlexRider3 Thanks this.
  9. abyliks
    4,138
    9,743
    May 2, 2010
    ludlow MA
    they are, my last company ride had disc all around and it would stop on a dime and bring back change at 100kish, my trucks a 97 though and still on drums
    Vitkouski and Siinman Thank this.
  10. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
    Disc brakes 100%. Cheapest insurance policy possible.
    Diesel Dave Thanks this.
  11. Diesel Dave
    9,712
    33,145
    Jan 20, 2010
    Hesperia, Ca.
    My tractor is disc, and I pull variable trailers with drums, ZERO issues.
    Oxbow, Big Road Skateboard and Siinman Thank this.
