Does DOT allow for fuel weight
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Jan 27, 2017.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    If you're over 12,000 on your steers will pre pass always give you a red light because it's monitored by a computer?
  3. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    there are some times where adding more weight to my drives will take weight off my steers. at 32k on my drives i am heavier on my steers than with 42k on my drives without moving my 5th wheel..............because at 42k on my drives i would have my pusher axle down....lol
    Bean Jr. and Jdm5jdm5 Thank this.
  4. Jdm5jdm5
    193
    60
    Apr 13, 2016
    You're saying to bring your tandems back not forward to put more weight on the drives?
    How much weight does 1 hole take off the steers?
  5. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    not what i am saying at all...lol i have a 3rd axle in my drive axle group, because it is ahead of my king pin it lifts some weight off my steers when i put it down.
    sliding your trailer tandems forward will take a weight off your drives witch will also take a fraction of the weight off your steers. the way to adjust steer axle weight is by sliding your 5th wheel on the truck. forward to add weight to the steers, back to take weight off the steers.
    different 5th wheel setups use different spacing on the locks so the amount of weight transfered per hole will varry from truck to truck
  6. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    I wouldn't say "always" but it is highly likely. My current load is 33,460 on the drives, got 75 gallons at the Pilot I-40x39 NM, going westbound into the AZ scales, prepass redlighted me. I was thinking, 'oops too much fuel' but it was 33,860 or something, she waved me on through. So the sensors in the road definitely can and will redflag a truck.
  7. mjd4277
    mjd4277 Road Train Member
    14,772
    45,601
    Oct 4, 2015
    Fitchburg,MA
    You were 140 pounds from the limit on the drives so you were good.;)
    How were you on your steer and trailer axles? As long as you were under the 80K gross limit you were gravy.
    Jdm5jdm5 Thanks this.
  8. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Those road sensors are remarkably accurate if you hit them just right.
    Colorado I 70 entering from Utah. I know I am heavy on drives just got fuel at Green River. I decided I was going to test them that day. Prepass red light. Go over scale they stop me for each axle group.
    11300...34300..34000
    Their computer I could see had me red flagged in it said tandem weight 34300 ... same as the static scale showed. Got a clean level 3 ... they were pretty cool there.
    Jdm5jdm5 and scottied67 Thank this.
  9. Jdm5jdm5
    193
    60
    Apr 13, 2016
    Just wondering for the future if I was over 12000 on the steers, even though I'm likely good up to 12500 would I likely get red lighted on pre pass for being a pound over 12000?
  10. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,650
    Aug 28, 2009
    Airlie Beach QLd
    If you've been driving for a while you should already know the answer to that one, some Dot are ok once you explain some are not, it really just depends in which state your in and which officer is on duty i've been 1200lb over on the drive axles and never got a ticket the officer just let me go slide the axles and reweigh If your in Oregon or Ca i'd be abit more vigilant.
  11. mjd4277
    14,772
    45,601
    Oct 4, 2015
    Fitchburg,MA
    Your guess is as good as mine. My company doesn't have Prepass so unless we get the bypass or closed signal we have to hit every scale house that's open.
