Door is Stuck
Discussion in 'Peterbilt Forum' started by slouder23, Jun 26, 2020.
  1. slouder23
    slouder23 Bobtail Member
    My door is stuck shut and can’t open it from the outside nor the inside of the truck. It’s stuck like the latch is open but is stuck shut if that makes any sense. It also won’t lock anymore like it’s caught up somewhere. Was wondering if anyone else had that problem.
  3. Judge
    92,045
    Rod inside door probably came off, fun time is to try and reach down by the window and open the door, coat hanger or something similar, then take off door panel & reattach.
  4. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    @pushbroom I’ve had the seatbelt get closed in the door and jam it. Had to put my shoulder into it to open.
  5. bad-luck
    bad-luck Road Train Member
    3,435
    6,326
    Nov 16, 2013
    Baltimore, Maryland
    The rod probably came off the latch, as they get worn and/or the plastic piece that holds the rod in place broke causing the rod to fall out. The best bet is to try and go down from the top of the door through the window channel.
  6. pushbroom
    pushbroom Road Train Member
    1,788
    7,397
    Sep 1, 2012
    Hinges can sag as well sometimes requiring the door to be lifter slightly to get it to unlatch.
    062 Thanks this.
