Downshifting a 13 speed
Discussion in 'Questions From New Drivers' started by Sythex92, Jan 7, 2018.
  1. Sythex92
    Sythex92 Bobtail Member
    Can I downshift while skipping gears? For example when I'm in 13 and flip the splitter to go to 12, can I leave the splitter in low and downshift to 10, 8 ,6? Or do I have to split each gear when downshifting?
  3. dnuke7
    dnuke7 Bobtail Member
    Oct 27, 2013
    Newport News, Va.
    Yes. As long as your rpms are in the right range.
  4. blairandgretchen
    13,998
    77,103
    Dec 9, 2011
    South west Missouri
    Just the way you described is fine, I do this often when light or empty.
  5. FLCRACKER
    FLCRACKER Medium Load Member
    344
    203
    Oct 11, 2013
    Lorida, FL
    If you don't split all you are doing is shifting a 9sp. Really a 13 is just a 9 where split the high side. An 18 is a 9 where where you can split the low and high side.
    diesel drinker and AModelCat Thank this.
  6. kenners76
    kenners76 Bobtail Member
    24
    25
    Jun 4, 2017
    When I first started it was a big ole pain to skip like that without grinding so I split them all now I barely every split on the down shift but always on the up shift
  7. Allow Me.
    10,787
    12,667
    May 28, 2009
    Rancho Mirage, Ca.
    yeah also skip while up-shifting (if you desire) o_O
  8. wore out
    wore out Numbered Classic
    17,469
    217,905
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I seldom split on a downshift. For me it's easier to drop a whole gear at a time.
    AModelCat Thanks this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Splitting on a downshift is make work. Edit... you are not trying to cross Impossible Hill...
    Take a whole gear.
  10. BigpopperRunner
    BigpopperRunner Light Load Member
    203
    103
    Jan 10, 2019
    The answer I was looking for! I thought we had to split on every single downshift but it would be a pain, might as well just use lo range and just drop whole gears. I am a little confused on matching the RPM's though as I tested in a 10 speed. It seems as if it's one number lower eg: 10 speed: 1+5 = 6 gear (15mph), 2+5= 7 (25 mph) gear, but in a 13 speed from what I have been observing is 1+5=5th gear (15mph) and 2+ 5 = 6 (25 mph). Also what is the purpose of the hi/lo range selector? I seen in some videos where when you upshift to lo (5th gear) pre-select it to hi range on 5th, release the throttle and immediately reapply the throttle so 5th hi can kick in. Is there a specific RPM we have to meet for the hi/lo range selector?
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Do not pre select SPLITS. If splitting say from 8L to 8H move the splitter forward and immediately let off so it drops in. For dropping half a gear do the same, break torque and blip the throttle up 200 she'll fall right in
