Dry van with rear forklift attached?
Discussion in 'LTL and Local Delivery Trucking Forum' started by MiguelT, Sep 14, 2021.
  1. MiguelT
    MiguelT Bobtail Member
    Sep 14, 2021
    Is there such thing as a dry van/box truck with rear forklift attached? Like how a sod or brick open flatbed trailer has the piggy back machines that can go over most terrain? Any links to that kind of a set up or pictures would be appreciated
    D.Tibbitt Thanks this.
  3. MACK E-6
    50,089
    238,961
    I’ve seen chicken hatcheries using those.
  4. jmz
    jmz Road Train Member
    1,214
    2,866
    Mar 9, 2018
    Great Plains
    Doesn’t seem very practical for a dry van. You can get the pallets off the tail, but then you still need a pallet jack to move the rest of them to the rear. At that point you might as well just use a liftgate and pallet jack. Make it an electric pallet jack if it’s something difficult to move.
    Maybe there’s some niche uses I’m not thinking about, and I’m sure you could get a custom setup if you really wanted to.
  5. jgarciajr40
    jgarciajr40 Medium Load Member
    696
    1,023
    Jun 18, 2016
    I was told by one of the accounts I service those moffetts are not as off road capable as you think. They get stuck all the time and they have to get someone to rock back and forth on the mast to gain traction on sand/dirt
  6. LTLdreamin
    LTLdreamin Light Load Member
    64
    55
    Sep 8, 2020
    I am experiencing this right now at my new gig. Got stuck in sand 3 different times this week. Moffetts suck on off road.
  7. nmill
    nmill Light Load Member
    193
    265
    Sep 7, 2018
    Maybe lowering the psi in the Moffetts tire would work? They always looked like their tires had good off road tread
  8. LTLdreamin
    64
    55
    Sep 8, 2020
    It's funny you said that, one of the veteran guys here told me to bring it to 30psi. I had no idea. They were at 50psi when I kept getting stuck. Thanks for the tip!
  9. jmz
    1,214
    2,866
    Mar 9, 2018
    Great Plains
    I found one out in the wild the other day. A Moffett on the back of some sort of specialized Tyson trailer, pulled by a JB Hunt Ag Services tractor. Clearly something poultry related, like what @MACK E-6 was referring to.
    McUzi and MACK E-6 Thank this.
