Dumb idea for DIY Generator
Discussion in 'Experienced Truckers' Advice' started by simonsocm, Jun 19, 2023.
  1. simonsocm
    simonsocm Light Load Member
    111
    67
    Aug 17, 2019
    So I had the dumb idea earlier today to look up 200cc diesel engines. I previously have looked up "small diesel generators" and got nothing. I found that 200cc and under diesel engines can be had on amazon for fairly cheaply though from chinese manufacturers. Now I was looking these up to possibly set up a diy genset to run AC in the truck at night and use diesel rather than carry gasoline as well.
    Looking up some info I found that a 200a alternator should only take about 3hp to run and the link at the amazon store below has an engine that's 5hp for $386.
    Futchoy
    I figure if someone really wanted to run their ac at night with a cheap generator you could probably buy one of these, slap a 200a alternator to some homemade belt setup and have a diesel generator for less than $750. Now personally I'd want to slap a big ####ing muffler and resonator on the engine as well. Aside from that though does anyone think this would or wouldn't work?
    Chinatown Thanks this.
  3. Big Road Skateboard
    7,118
    40,410
    May 2, 2021
    Yeah, it would work. Idling when necessary would be cheaper.
  4. LOTSO
    LOTSO Heavy Load Member
    882
    2,120
    Mar 28, 2023
    As long as you never park next to me have at it...:oops:
    ncmickey and bzinger Thank this.
  5. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,916
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    I dont pinch pennies to the point where I cant idle the truck.
    RockinChair Thanks this.
  6. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    If it's not liquid cooled, it might be hard to mount it where it can get enough air flow.
  7. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    Then California would require a emissions on it. The smart way today is an electric APU with a couple extra batteries to run them.
    Bean Jr. Thanks this.
  8. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Don't go to commiefornia, problem solved
    RockinChair and Snailexpress Thank this.
  9. Gridaxe5588
    Gridaxe5588 Light Load Member
    126
    168
    Nov 23, 2022
    IMHO a 200 amp alternator is overkill, I have a 12kw generator on my truck with 4cyl Kubota diesel and it has a 30 amp alternator which charges all my batteries in an hour, while running my RV style roof air
    simonsocm Thanks this.
  10. simonsocm
    111
    67
    Aug 17, 2019
    Easy enough to add a radiator fan to blow over it.
  11. bzinger
    bzinger Road Train Member
    16,657
    66,198
    Dec 10, 2014
    omaha , ne
    Go on ebay and you can buy those 3 hp air cooled Diesels all day long for under 300 bucks .
    Downsides are they are noisy, made in China and smokey when under a load .
    They are getting popular for repowering small engine gas powered equipment , I don't know about the longevity of them but so far they are getting good reviews and I'm going repower my snowblower with one this fall .
    Oxbow Thanks this.
