Engine damage with high rpm
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Aqel1982, Oct 19, 2018.
  1. Aqel1982
    Aqel1982 Bobtail Member
    4
    Jul 6, 2018
    I was going downhill last week on 5th gear . Rpm was above 36000
    Multiple codes showed up including
    Stop engine light.
    It has been few days in freightliner.
    Could the damage be severe???
    Thanks
  3. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,649
    Aug 28, 2009
    Airlie Beach QLd
    Sure its not 3600 rpm not Thirty six thousand even a Formula 1 racing car wouldn't rev that high. When descending a steep hill you've got to put it in a gear that will hold the weight pushing so you don't need to apply the brakes and it should also not allow the truck to do what occurred to you namely building up the revs you were in a bit to high of a gear try going down a few more next time you take that hill/ mountain, also try using your engine brake /jake brake to slow it down if the lights stopped flashing after this happened everything should be ok however when you over rev an engine anything can break the head could drop a valve and do some serious damage.to the pistons. so hopefully you got away with it and can learn from this experience.
    Rideandrepair and Crude Truckin' Thank this.
  4. wichris
    wichris Road Train Member
    4,492
    9,250
    Jan 17, 2011
    If it ran 36000 rpm do whatever you can to keep that motor.
  5. supersnackbar
    20,099
    52,627
    Aug 19, 2007
    Your Town, USA
    Most semi engines don't like being rev'd over 22-2400, with 4 valves per cylinder, they tend to float the valves and/or break connecting rods. Smaller diesels like in pickups and passenger cars can handle it, but big displacement diesels tend to come apart...in fact, an over rev like that may have voided the engine warranty.
  6. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    Let's just say, you definitely didnt do that engine any favors. That's about where things start flying apart in a big engine. 11 years ago, my boss had an MBE4000 make it to 3900 RPM before it blew its guts out on Homestake pass.
    bzinger and Rideandrepair Thank this.
  7. AModelCat
    164,655
    Best case scenario you got lucky and the codes were just alerting you to engine abuse. Worst case scenario your engine is toast because the valves kissed the pistons or something to that nature.
  8. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    Depending on gearing that should have been about 999 mph.
  9. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    I hope with a little gearing tweak he can break the 1000 mph mark...
  10. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    That engine must've been screaming? Lucky a rod didn't come out the block to shake hands with you.
    SAR, snowman_w900, Dino soar and 4 others Thank this.
  11. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    I'm curious what kind of truck/engine this was?
    stillwurkin Thanks this.
