Engine ecu active fault code P220E93
Discussion in 'Volvo Forum' started by Pal22g, Aug 16, 2020.
  1. Pal22g
    Pal22g Bobtail Member
    9
    6
    Nov 10, 2019
    Hello Masters
    Got an engine ecu Active fault code P220E93 on my volvo 2016 vnl 670 , d13.
  3. Judge
    92,482
    SA 16 DTC P220F93
    Found this, said something about Output exhaust sensor, maybe it’ll help
    Pal22g Thanks this.
  4. Pal22g
    9
    6
    Nov 10, 2019
    Does it has to do anything with nox sensors.. thinking of replacing both nox sensors and 7th injector
  5. Kalaramna
    Kalaramna Bobtail Member
    Jan 21, 2022
    Hi how you able to fix this code. I have the same code in my volvo
  6. MIg25
    MIg25 Light Load Member
    73
    20
    Apr 10, 2020
    Fort Lauderdale - Florida
    Hello,
    This trouble code is related to NOx sensor - series 1 sensor 1. You can try removing and cleaning the sensors with ether or contact cleaner, or depending on your mileage you might need to buy a new sensor.
    This is not an expensive or complicated fix.
