Engine fan not coming on
Discussion in 'Experienced Truckers' Advice' started by RepoweredRookie, Jul 13, 2024.
  1. RepoweredRookie
    RepoweredRookie Light Load Member
    158
    134
    Apr 16, 2019
    What’s up Guys.
    I got a 1999 Freightshaker Century with an S60 12.7 Detroit.
    Fan should be coming on when water temp his 180 degrees, but it doesn’t. I have to maually use my engine fan switch everytime now. Do you guys have any idea what I could check?
    -have power at solenoid switch
    -I did replace coolant temp sensor
    Thank you for any suggestions!
  3. Big Road Skateboard
    7,202
    40,931
    May 2, 2021
    Fan shouldn't come on till 210-212*
  4. Concorde
    Concorde Road Train Member
    5,506
    19,598
    Jun 29, 2016
    West Melbourne Florida
    Shouldn’t come on at 180 imo but I’ve never owned a Freightliner.
    Mine have always come on around 210
    My normal operating temp is 181-183
  5. RepoweredRookie
    158
    134
    Apr 16, 2019
    Oh wow, I think you guys are right. The thermastats are 180 degree, which means the fan should be 10-20 higher. OK maybe I got confused I will run it down the road and recheck it.
  6. RepoweredRookie
    158
    134
    Apr 16, 2019
    My running temp is 175-180. So when I saw 190 and no fan the other day I may have got spooked for no reason. Thanks for the response, I’ll double check.
  7. Big Road Skateboard
    7,202
    40,931
    May 2, 2021
    Fan on temp will not change with lower thermostats. It is set in the ECM by Detroit. I don't even think you can change fan on temp, just duration.
  8. blairandgretchen
    13,987
    76,969
    Dec 9, 2011
    South west Missouri
    Same here, same motor.
    RepoweredRookie and Concorde Thank this.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    215 is what I've been seeing in cat, Cummins, and paccar. And the newer detroits.
  10. bryan21384
    bryan21384 Road Train Member
    15,800
    34,443
    Sep 18, 2009
    Memphis, TN
    180?!??! That's around what your truck is supposed to run at. I thought the fan came on at 220, but to be fair it's been a while since I've been in a Cascadia.
  11. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    Read the manual.
    RepoweredRookie Thanks this.
