Espar bunk heater not working when below 0 degrees
Discussion in 'Experienced Truckers' Advice' started by Kenworth6969, Feb 13, 2025.
  1. Kenworth6969
    2,980
    9,335
    Jul 3, 2020
    When it gets super cold my espar heater gives no flame detected code.
    20 degrees outside works fine but when it's around 0 it stops working.
    Could it be fuel geling within the line itself?
    Anything that can be done here?
  3. D.Tibbitt
    157,124
    Does it smoke when it starts up, when it is working normally?
    If no then I would just suspect it could be the fuel line gelling up. You can also check the fuel pump as well. You should hear it clicking/pulsating outside the truck . I had one that would get gummed up over time with the crappy fuel nowadays.
    If it does smoke alot when starting then you will have to take it apart and clean it, burning off the excess carbon build up inside the burn chamber, there is also a glow plug element in there that can go bad as well..
    but if yours stops working only when it's really cold it probably just the fuel line getting gelled, maybe if you can find something to insulate it or wrap around the line , it may help
  4. wichris
    wichris Road Train Member
    4,498
    9,255
    Jan 17, 2011
    When I had them on the trucks we would drop the fuel line into kerosene/fuel injector mix and run for an hour. Burn everything out, no more smoke when it started.
  5. Ridgeline
    22,724
    123,366
    I have a bunch that freeze up when it hits -10ºF, it is always the fuel that gells up.
    As for blowing out the carbon, you can't, they have to be removed and cleaned, you can get a lot of carbon out, but it never cleans it out completely.
    Preventing the buildup by running them hot and doing so every month of the year.
  6. blairandgretchen
    13,933
    76,586
    Dec 9, 2011
    South west Missouri
    More than likely gelling in the line. My gen set was doing the same at 10 degrees. No treatment in fuel.
    Solution - bottle of Howes in tanks.
    Flat Earth Trucker and tscottme Thank this.
  7. Arctic_fox
    4,509
    25,484
    Sep 16, 2016
    Like others said fuel in line gelling is most likely. Bottle of howes or if its still an issue try some heat tape and/or insulation around the line. Otherwise it may be gummed up and need a deep clean.
  8. jeffman164
    jeffman164 Medium Load Member
    630
    587
    Dec 4, 2012
    I run kerosene exclusively. Knock on wood. No gel up yet.
  9. Flat Earth Trucker
    4,315
    16,597
    Nov 19, 2018
    I'm in a Freightliner with 140,000+ miles and my Espar bunk has went on strike. A nice Freightliner technician arrived and informed me that there is a national campaign going affecting 37,000 vehicles.
    The common culprit seems to be the two foot length of tubing drawing fuel from the tank.
    Maybe you can have your issue fixed at no cost to you.
    Update: 20250213_205432.jpg
    The thick plottens.
  10. 86scotty
    86scotty Road Train Member
    4,706
    12,917
    Aug 27, 2017
    Appalachia
    I would get on Ebay/Amazon and get a 2 or 3 gallon tank for one of the cheap Chinese diesel heaters. Mount it on your catwalk. Keep kerosene in it or heavily anti-gel treated diesel and drop the line into it instead of the main tank when it's super cold out.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had a new Western Star that had the same problem. After trying a lot of different things, it came down to the wiring.
    The dealer wired it through the trucks low voltage disconnect which didn't have a heavy enough gauge of wire to supply the heater, too much of a voltage drop. Worked fine at warmer temps.
    I wired it directly to the batteries using the called for wire gauge and it worked great after that.
    mitmaks and krupa530 Thank this.
