Facing issues on curves as new truck driver
Discussion in 'Experienced Truckers' Advice' started by mandeepBatth, Aug 30, 2022.
  1. mandeepBatth
    mandeepBatth Bobtail Member
    Aug 30, 2022
    Hi all,
    I started as a truck driver 2 months ago, i face issues on curves. sometimes i apply brakes on curves and turns where i should not apply brakes, also i am unable to make balance while overtaking another truck on curves and turns.
    appreciate any advice on it,
    thanks
  3. REO6205
    REO6205 Road Train Member
    13,168
    60,507
    Feb 15, 2014
    California.
    This is an easy one. Pass only when going in a straight line. Do not pass on turns. Ever.
  4. Munch75
    Munch75 Light Load Member
    202
    437
    Aug 29, 2021
    Always remember to slow BEFORE a turn. Easy rule of thumb- taking a curve slower than you could allows you another chance at taking it again differently depending on load weight and conditions. Getting it wrong and too fast easily leads to that being your last attempt.
    It is your truck, your load, your life.
    Any super trucker barking on the radio is likely the ones you find in emergency ramps, ditches, or on the barriers blocking up traffic for hours.
  5. blairandgretchen
    14,031
    77,497
    Dec 9, 2011
    South west Missouri
    Brake before the turn, slow down.
    Accelerate through the turns .
    Don’t pass trucks in a curve. Nor near an on/off ramp. Check shoulder ahead before you pass.
    Pass quickly and clean, or not at all.
    Kept me safe for 18 years.
    wore out, Woodys, InTooDeep and 11 others Thank this.
  6. SmallPackage
    5,884
    18,897
    Dec 20, 2019
    Marion Texas
    Slow down on approaching the curve without using brakes if possible. Sometimes this means under the posted speed. If you have to use brakes try to have them released at a safe speed before you enter the curve. When you get into end of the curve lightly throttle out to plant some power to the ground and resume speed. Not using the brakes abruptly helps keep you stable, balanced, and up right.
    Keep your mirror on the inside edge of the center line on a right hand curve helps keep you from going into on coming lane. On a left hand curve keep trailer tandems barely on that center line.
  7. SmallPackage
    5,884
    18,897
    Dec 20, 2019
    Marion Texas
    I think he may have meant on coming truck. At least I hope so.
  8. AModelCat
    166,473
    Maybe passing on a curve on a 4 lane highway?
  9. Moosetek13
    Moosetek13 Road Train Member
    15,086
    19,230
    Nov 1, 2010
    Burnsville, MN
    Some people need to learn to not be so much in a hurry?
  10. jmarc77
    jmarc77 Light Load Member
    162
    428
    Sep 17, 2021
    Were you taught the Smith system? I thought some of it was silly, but the one thing that helped me as a new driver was aim high in steering. Look far ahead and it will be much easier to drive smoothly and correctly maintain your lane.
  11. God prefers Diesels
    4,198
    22,269
    Jun 26, 2020
    South Texas
    I pass on the outside. If you have a special set of matched tires like me, it WILL HOLD!!
