Failed Smog Test
Discussion in 'Ask An Owner Operator' started by WhatsHaulin, Jan 5, 2026.
  1. WhatsHaulin
    WhatsHaulin Bobtail Member
    21
    7
    Apr 26, 2023
    My truck recently failed a smog test here in California due to a fault code SPN 96 Fuel Level 1 which caused the MIL light to come on. Yes, I know I know you guys are going to tell me to move out of CA because of all their BS restrictions. Anyways, does this have to do with the fuel sender? If so, it seems like it will be a minor fix, but what kind of cost do you think I should be expecting? TIA
  3. blairandgretchen
    13,971
    76,822
    Dec 9, 2011
    South west Missouri
  4. D.Tibbitt
    157,286
    Sound like its just a sending unit problem? If it just needs replaced, you do it yourself and id assume parts are pretty cheap
    Diesel Dave Thanks this.
  5. SmallPackage
    5,813
    18,627
    Dec 20, 2019
    Marion Texas
    Was it actually tested to see if it was out of spec or did they just fail it because the light was on? False codes happen all the time without performance issues.
  6. WhatsHaulin
    21
    7
    Apr 26, 2023
    He tested it and showed me that specific code was the reason.
  7. SmallPackage
    5,813
    18,627
    Dec 20, 2019
    Marion Texas
    So it failed because the code was there but what did the actual stack tester say? Phantom codes mean nothing. They happen all the time. Diamler/ Chrysler’s ecm and tipm’s are known for this.
    OlegMel Thanks this.
  8. Diesel Dave
    9,712
    33,145
    Jan 20, 2010
    Hesperia, Ca.
    Don’t try to pass any test when any Check engine light is on. And if you clear it, the truck has to be driven certain amount of miles before the computer reads all is clear and functioning normally. Now for that code, take it to a reputable shop and have them analyze it, fix it. Like mentioned above, if you can replace and fix the “Correct” sensor, go for it. But the truck has to be driven (don’t know exact mileage) for the computer to reset to read all sensors are working properly.
  9. WhatsHaulin
    21
    7
    Apr 26, 2023
    So does that mean the light will stay on until the truck has been driven a certain amount of miles? How would I know it's been fixed or not?
  10. Diesel Dave
    9,712
    33,145
    Jan 20, 2010
    Hesperia, Ca.
    Fix the issue for starters, then the code should be cleared. Sometimes the code clears itself once the problem gets fixed. But I recommend to have it cleared. Then it has to be driven for certain amount of miles for the computer to read all systems. Sometimes you can get a ghost code. I’ve had them before and cleared them and never came back. It’s a hit and miss issue with these systems.
    WhatsHaulin Thanks this.
  11. Diesel Dave
    9,712
    33,145
    Jan 20, 2010
    Hesperia, Ca.
    Usually the first sensors to go out are the inlet and/or outlet sensors, and those are the most expensive ones, mine cost me $6-$700 each. That was in 2021. I bought OEM.
