Fire stick 2, cobra Ltd 29
Discussion in 'CB Radio Forum' started by bburgess230, Jun 27, 2019.
  1. bburgess230
    bburgess230 Bobtail Member
    Just bought cobra Ltd and Firestik, mounted to tool box but get antenna red light when mic pressed. Tried grounding, nothing changes, I unhooked antenna from mount and held in my hand and light goes away. What gives? Calibrated according to instructions.
  3. Dan1918A2
    Dan1918A2 Bobtail Member
    14
    17
    Sep 24, 2010
    Peachtree City, Georgia
    Do you have decent SWR readings? The SWR meter on the 29 isn’t the best, but it should work well enough. Your red antenna light is likely because your antenna is either too short or too long. My 29 with a Wilson 2000 antenna showed a red light until I properly tuned it by shortening the whip just a little at a time.
  4. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    As Dan said, your SWR is probably too high. Look in your radio manual for instructions on tuning. Hopefully you have the adjustable tip Firesticks as it is easier. If you have the kind that must be trimmed just take it slow 1/4 in at a time or less when you get close to optimal SWR.
    Here is one of the many sites with tuning instructions: Tuning your Antenna, How to set the SWR - www.WalcottRadio.com
  5. Ridgeline
    22,720
    123,295
    Wait wait wait ....
    Before you tune anything, please describe what you mean by grounding?
