Firearms and ports
Discussion in 'Ask An Owner Operator' started by tnc110, Aug 28, 2022.
  1. tnc110
    tnc110 Light Load Member
    138
    81
    May 22, 2016
    Specifically port of Baltimore. Can a driver check a firearm at the gate and retrieve it when leaving? I assume the firearm can not remain in the truck when on port property?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,575
    9,940
    Mar 30, 2014
    I don't know about Baltimore, but the one I go to, I used to leave it in its holster until I lost it in a boating accident.
  4. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,607
    Jun 3, 2018
    well according to some people give it a year or two, and you’ll find it. Just be on stand by when the water recedes.
  5. RockinChair
    RockinChair Road Train Member
    5,413
    14,612
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Meanwhile the climate change alarmists are all up in arms (pardon the pun) about how global warming is supposed to make sea level rise and flood coastal cities.
  6. tnc110
    138
    81
    May 22, 2016
    That’s a great excuse if you are trying to say you lost one but what is your excuse if they find one where they are prohibited?
    Bean Jr. Thanks this.
  7. Bean Jr.
    5,575
    9,940
    Mar 30, 2014
    This one is so tranquilo. A normal one, I wouldn't do that. I kept a safe in my truck and locked it up at shippers and receivers that felt a little more serious about it.
  8. JonJon78
    JonJon78 Road Train Member
    7,246
    43,303
    Jul 1, 2018
    They won't be searching your truck there, keep it unloaded and put away. You'll be fine.
  9. Judge
    92,967
    I kept mine in a case in the truck in the bunk, never had any issues at rails or ports.
  10. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    No need to worry about a search at Dundalk/Seagirt. However, MD hates your right to bear arms and have many restrictions on said right so make sure you have the firearm unloaded, in a covered holster or box and tucked away in the sleeper.
    RockinChair, wis bang and JonJon78 Thank this.
  11. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Last port I went to I just lost it outside the gate, in the ocean. Found it on the way out.
    Big tip, don't try a military base, mofos check every where every time.
    Bean Jr., RockinChair and Opendeckin Thank this.
