Flat repair/corner sidewall
Discussion in 'Ask An Owner Operator' started by mitmaks, Apr 4, 2022.
  1. mitmaks
    mitmaks Road Train Member
    2,593
    2,115
    May 16, 2014
    I got 4" nail right in corner. There's no way to fix it or shop just doesn't want to take risk and make extra money off of new tire?
  3. D.Tibbitt
    158,091
    Have some pics?
    Big Road Skateboard Thanks this.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    If the puncture is in the tread face it’s repairable, not the sidewall. Shops on the road are more than willing to move that demark and 1/8” or so if there’s a new tire sale in the balance. Same story forever, they never have a used one or a cap in stock in that size, but they always seem to have one that size with the sticker still on it.
  5. Munch75
    Munch75 Light Load Member
    202
    437
    Aug 29, 2021
    If the mechanic/tech told you- likely not in a safe to repair spot and not worth the potential liability. Mechanics/techs will usually get paid more by performing the repair than a tire swap. If it was a sales guy then it's 50/50. Generally you have to keep in mind where the tires flex when in motion. Usually the section BETWEEN each outter channel is safe. Outside that towards each sidewall sees the most flex and heat transfer increasing the risk of a failed repair.
  6. boneebone
    boneebone Road Train Member
    2,297
    2,373
    Mar 13, 2009
    You could try doing a section repair which is a plug and a patch.
  7. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    If it has lots of tread left I might try a plug kit and a patch on the inside. But good luck getting a tire shop to do it. Liability problem. A patch or plug on the sidewall gets to much movement from tire flex and often won't hold
    omardten Thanks this.
  8. Aamcotrans
    Aamcotrans Road Train Member
    1,044
    1,803
    May 24, 2016
    Strasburg, Va
    If the whole is inside the first tread groove then it is not repairable. Anything you put there be it a patch or plug will flex and come out
