Florida Backing test
Discussion in 'Questions From New Drivers' started by Seth0194, Jun 20, 2023.
  1. Seth0194
    Seth0194 Light Load Member
    96
    118
    Mar 13, 2023
    North Florida
    So I discovered Florida CDL backing test is graded on errors committed. Does anyone who has taken the test etc know how many errors are allowed during the backing portion?
    Thanks, and be safe out there.
  3. tscottme
    tscottme Road Train Member
    Why not call the FL DMV, or whatever they call the office that gives the tests?
    Seth0194 and Opus Thank this.
  4. CalculatedRisk
    CalculatedRisk Heavy Load Member
    789
    1,000
    Jul 26, 2022
    Space Coast
    I believe it is 12 points total.
    Seth0194 Thanks this.
  5. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    12 points total
    2 points for every cone (encroachment) you hit
    1 point for every extra pull up. You get a free pull up on the straight line, 2 free pull ups on the offset, alley and parallel
    10 points if you blow the horn saying that you are in the correct final position and you aren't.
  6. Frank Speak
    Frank Speak Road Train Member
    4,568
    14,056
    May 3, 2016
    It’s been about 11 years for me, but @Todd727 answer sounds right from what I can remember.
  7. Frank Speak
    4,568
    14,056
    May 3, 2016
    p.s. The backing maneuver you get asked to do is luck of the draw, at least it was when I took the test. Lucky me (NOT!) got selected for the offset. On the plus side, I somehow managed to nail it without so much as a single pull up. That was 100% luck. Lol
    Seth0194 and 88 Alpha Thank this.
  8. Todd727
    300
    583
    Jun 7, 2021
    I know in MS you do 3:
    1) Straight
    2) One offset (luck of draw which way)
    3) Either 90° or parallel
    Frank Speak Thanks this.
  9. aussiejosh
    aussiejosh Road Train Member
    4,776
    5,589
    Aug 28, 2009
    Airlie Beach QLd
    Yeah always wondered why a CDL test requires a reverse test as who reverse parks with a Tractor - trailer? However it does show if you know how to reverse, as long as you don't hit the curb, and back in straight you should be fine. Getting you to back onto a dock should be the standard test not reverse parking against a curb.
  10. Todd727
    300
    583
    Jun 7, 2021
    I think you mean the parallel parking and I've probably done parallel more than backing in to a parking spot lately. Parking on the street can be quite common over here.
