Fluid leak help.
Discussion in 'International Forum' started by Thetrashnoob, Oct 25, 2020.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    293
    55
    May 30, 2019
    Hello all, I just purchased a 01 4700 and the drivers side front wheel I have a leak of some sort. The whole inside of the rim is covered in oil of some sort and it’s leaking and leaving a puddle right below the caliper? Not sure about the terminology. Just looking to see if someone could help point me in the right direction to track down the leak.
    Thanks
    blairandgretchen Thanks this.
  3. AModelCat
    159,803
    Sounds like a blown wheel seal.
  4. Thetrashnoob
    293
    55
    May 30, 2019
    Dumb question as I don’t know very much, If it was a wheel seal, wouldn’t it be leaking on the outside? Before I picked it up the brakes were just done as well, so I was thinking it could have been related to that
  5. AModelCat
    159,803
    Nope. Wheel seal is on the inside. Hubcap is on the outside.
    Rugerfan and blairandgretchen Thank this.
  6. Thetrashnoob
    293
    55
    May 30, 2019
    Thanks, I’m going to have to look into it a bit more to confirm that it is the seal. But I’m not sure what else it could be.Will I be able to drive it somewhere to get it fixed?
  7. LameMule
    LameMule Road Train Member
    1,148
    7,415
    Jan 19, 2020
    Montana
    I always like to take a leak next to a buddies rig then tell them it looks like they have a fluid leak.
    Stand back and watch them rub the mystery fluid between two fingers and smell it in an attempt to identify it.
    Not sure if that helps but thought I'd share...
    Almost certainly a wheel seal like he said. Cheap and easy fix. Good time to inspect brakes and wheel bearings.
  8. Thetrashnoob
    293
    55
    May 30, 2019
    A wheel seal looks like It’s a cheap and easy fix, unfortunately I don’t have the tools or the know how to do it in my driveway otherwise I’d attempt it!
  9. LameMule
    1,148
    7,415
    Jan 19, 2020
    Montana
    Typically the tools cost more than the parts. You'll be money ahead to buy the tools for it because it's a common failure and huge savings to do it and your brakes yourself.
  10. blairandgretchen
    13,387
    72,021
    Dec 9, 2011
    South west Missouri
    Don’t drive it too far - at all.
    Top it up through the little cap, and get her fixed quickly.
    Likely your shoes will be soaked - replace them.
    How many miles on this leak?
    God prefers Diesels Thanks this.
  11. Thetrashnoob
    293
    55
    May 30, 2019
    I know I need to buy the tools, certainly on the list. Even if I got the tools, not sure it’s something I’d be confident doing in my driveway, if I mess it up it’s gonna cost a bit to get it towed somewhere to be fixed
