forgetting to lowering landing gear...
Discussion in 'Questions From New Drivers' started by FrankieCarbone, Mar 10, 2020.
  1. FrankieCarbone
    FrankieCarbone Bobtail Member
    9
    11
    Mar 10, 2020
    Orlando FL
    from doing a search, not just here but in general it seems like im the only idiot this has happened to. I see alot of forgetting to uncouple the hoses, but never this.
    I always been afraid of this happening, and after 7 or so years as a truck driver it finally happened to me today. As much as i am embarrassed by this im also kind of worried what could happen if my company finds out. I mean there was no damage, it happened in the lot, and when i took off it actually never completely fell on the ground because the frame of the tractor stopped it, i quickly got out and to try and save some dignity (kind of like when you slip in public and just get right back up and act like it never happened) went to work on the crank to get it back up, it wasent easy but i got it lifted enough to be able to pull out the tractor.
    The landing gears were slightly bent but i think that was more because of the angle i lifted them back up, but after i drove away the trailer looked normal.
    My question is, is this something that a company would consider to be a accident? like something im supposed to go and tell my supervisors about right away?
    Dino soar, rachi, tscottme and 5 others Thank this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    hammer down. some landing gear legs are welded not straight anyway. just say i dont recall. remember its i dont recall
    Dino soar, Opus, Badmon and 1 other person Thank this.
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    as long as they are not folded up or in or out and bat wings and braces are good. then hammer down. theres nothing to report
    Badmon Thanks this.
  5. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,606
    Jun 3, 2018
    It has happened to many people here. Most wont admit to it.
  6. Numb
    Numb Crusty Curmudgeon
    4,351
    10,339
    Jan 30, 2012
    Charlotte, N.Carolina
    I've done it a time or 2 in 35 yrs. lol
    crap happens.
  7. Deere hunter
    2,171
    10,542
    Aug 5, 2017
    Shallowater Texas
    I’ve done it so many times I couldn’t count it!!
    Never could find the handle on that rgn.:biggrin_25523:
  8. MACK E-6
    50,146
    239,555
    There are two types of drivers, the ones that have done this and the ones that lie and say they don’t. :biggrin_25523:
    Woodys, Kyle G., G13Tomcat and 16 others Thank this.
  9. Vic Firth
    Vic Firth Road Train Member
    1,843
    4,307
    Jan 19, 2016
    Indiana
    I’ve forgotten to raise them, luckily it was on gravel and I only moved a foot or so when I recognized my mistake.
  10. Judge
    92,787
    Start a system, lower gear first, then airlines, if someone distracts or if your mind wanders and you go to leave you just pull against the 5th wheel.;)
    Hooking after checking pin then raise legs, then if you get side tracked, you’ll know when you release trailer brakes and air blows out line. ;)
  11. Moose1958
    Moose1958 Road Train Member
    15,298
    33,966
    Dec 17, 2010
    Williesburg, Virignia
    Well, I guess I am telling a lie. I have never pulled out without lowering the landing gear. I, however, have done everything but remove the glad hands more than once. It seems this crap happens when I am trying to multitask. Something always happens. I also have backed under and my 5th wheel was way too low and the trailer kingpin went behind the 5th wheel. In the process, I damaged my reefer unit door and busted my QC antenna.
