Freezing cooler product
Discussion in 'Refrigerated Trucking Forum' started by Cargo Kara, Jul 11, 2014.
  1. Cargo Kara
    Cargo Kara Bobtail Member
    Ok, so we loaded a pick- one stop load. Freezer product. Got to the customer and they said over 1,200 cases were fine and accepted. However, 350 cases that were in the front quarter of the trailer (5 pallets) were thawed and refused. Had to take it back to the warehouse. Took the product back, and they said it temped at 19 degrees.
    - The details. Ran it 2 days at 0 before getting to the customer. Customer did not have the ability to temp it so they said it just looked thawed. Ran it at -10 for the ride back to the warehouse. Is it possible to "thaw" half a trailer??... or is it more likely the product that they actually put on the trailer was cooler product, and was not frozen, and I actually dropped the temp over the 3.5 days it was sitting on my trailer...
    Anyone know how long it takes a reefer unit to freeze cooler product? Anyone know if it is possible for a trailer to thaw out only the nose of the trailer while leaving the rest of the product frozen?
    Any help would be appreciated. We anticipate a claim, and I want to be ready for it.
  3. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Someone should have temped it at the receiver and I advise in the future temp the product that's being loaded as its loaded then you can refuse to freeze someone's product that they should have frozen before loading
    CondoCruiser Thanks this.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Was this ice cream?
    Was your unit shut off unloading and they temped the outside case? You have to be careful in this extreme heat shutting down while they unload whether the unloader likes it or not. If it was a laser temp reader the battery running low will give a false reading
    I have a feeling the product wasn't ruined but gave the illusion of it from them circumstances (trailer warming up and only outside of box warming up). They should of checked a box a case or two in towards the core of the pallet.
    19* is still frozen but not hard frozen. Unless it was ice cream or some other crystallized dairy product it could of been saved. Temperature recorders save situations like this.
    Check the reefer unit for any alarm codes.
  5. Flyer
    Flyer Light Load Member
    183
    88
    Jan 20, 2008
    Did you download the datalogger ? It will show setpoint, return air temp, ambient temp. All pertinent parameters related to the operation of the unit. Have had several instances, one as recently as last week where ryan recorder on a load showed no lower than 38*, downloaded datalogger (das), showed 34.3* to 34.8*. Stopped the claim process right there. Had one similar to yours last year, same thing downloaded das, unit doing its job, no claim.
  6. wichris
    wichris Road Train Member
    4,522
    9,327
    Jan 17, 2011
    Tell them to put a tray of ice cubes in the freezer and that you want some to be -10 and others to be 19. When they can do that they have a valid claim.
  7. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Any chute damage? Was load ran continuous the entire time? But usually with chute damage it's the rear of the trailer that goes out of spec. Could be [some of] the product was not thoroughly frozen solid to begin with. What was the product?
  8. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    Seems highly unlikely that frozen product would thaw in the nose. Tail, maybe but not the nose. Sounds to me like the product was loaded warm. As others have asked, what was it? Did you load it from a manufacturer or cold storage?
    jbatmick Thanks this.
  9. willisl64
    willisl64 Light Load Member
    77
    115
    Jul 12, 2014
    Last year hauled a load of fresh chicken. Bills said 20 degrees...shipper insisted on 20 degrees...arrived at receiver 2 days later and load was rejected due to the top of each combo having 8 inches of frozen chicken on top...Receiver told us load should have been held at 30...too late. Claim went to the shipper, due to the bill stating 20 degree temp. So yes, you can easily freeze fresh product over the course of 3 or 4 days.
  10. Cargo Kara
    Product was Bacon.... expensive bacon. loaded out of a warehouse. I think a claim is pending, NO temp was taken at loading, nor was it taken at the customer, the assumption would be they HAD to have had the product thawed when it was loaded, and the freezer actually dropped the temp to 19 degrees... IF it was actually thawed at the customer. Trust me ...we will confirm temp at loading in the future, however, I am not sure how to argue THIS claim. Also, it is an older trailer, not temp recorder to prove the reefer unit ran OK. Not sure if anyone has been able to prove how long it takes a reefer unit to "freeze" cooler product. So if they put 32 degree product on a reefer unit, is it reasonable to say after 3 days it would be down to 19? If they put frozen product on the trailer... is it even possible for a trailer to thaw half a trailer?- no issues with the shoot.
  11. Flyer
    183
    88
    Jan 20, 2008
    Kara, how did the receiver sign your bills ? Is it possible, anything's possible I suppose, but highly unlikely. Sure it could come down to 19*. If product was loaded "tight" against the back doors it could have shut off return air to unit, hindering circulation.
