Freightliner 06 century
Discussion in 'Ask An Owner Operator' started by DesiTrucker, Jan 8, 2016.
  1. DesiTrucker
    DesiTrucker Light Load Member
    260
    67
    Apr 11, 2013
    Nj
    The truck has been sitting since Christmas
    Started on Monday
    Tuesday would not start
    Today(Friday) I gVe it a jump and started
    Detroit60 motor
    What's the normal output I should be looking for on alternator. After letting it idle about 15minites the volts were around 13-13.5
    Is this normal?
    Also, had a check engine sign come on during idle but when i took it for a drive around the yard it went away.
    Anyone else have this sort of problem?
  3. LaComa
    LaComa Light Load Member
    85
    44
    Savannah, GA
    I would pull the batteries go have them tested. I had the same thing happen over the holidays I ended up having a bad cell in each of the batteries.
  4. blairandgretchen
    13,932
    76,571
    Dec 9, 2011
    South west Missouri
    Give her a good run, hour or so on the road to charge them batteries.
    13.6 - 14.2 should be normal alternator output.
    Alternatively, remove all batteries, clean terminals, slow charge, and test.
    Check engine light may be associated with low voltage.
    Check for any phantom drain on battery system.
    truckthatpassesyouby Thanks this.
  5. blairandgretchen
    13,932
    76,571
    Dec 9, 2011
    South west Missouri
    Just make sure you fully charge batteries before load testing.
  6. DesiTrucker
    260
    67
    Apr 11, 2013
    Nj
    Update
    The truck started just fine
    Drove it around for about an hour or so and it was showing 14v on the meter.
