Front axle weight
Discussion in 'Questions From New Drivers' started by mitmaks, Jun 6, 2016.
  1. mitmaks
    mitmaks Road Train Member
    2,592
    2,113
    May 16, 2014
    What s the front axle weight limit?
    Ive been told 12500 but someone said 13100, not sure where they got that from.
    What would be overweight at the scale?
    Thanks
    Dominick253 Thanks this.
  3. Clyde07
    Clyde07 Heavy Load Member
    809
    1,927
    May 28, 2013
    Neither. It's according to your tires and axle rating. For all practical purposes, whichever is rated less would be the limit.
    Upright, Dominick253 and brian991219 Thank this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    12000 is a rule of thumb. Open your atlas and see what the states you are driving through state for max, as there are several requirements. Now look at the rating on your tires. Last look at axle weights usally on the door jam.
    Front axle weight is the lesser of the three.
    -Steven
  5. Moosetek13
    Moosetek13 Road Train Member
    15,006
    19,072
    Nov 1, 2010
    Burnsville, MN
    Generally 12,000.
    My 5th wheel is set to give a steer weight of around 12,300 with full tanks and a full load. It has never been an issue.
    tow614 and Dominick253 Thank this.
  6. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    Clyde07 has the correct answer.
    People always think it is 12,000 because if you have 34,000 on the drives and 34,000 on the trailer tandems that leave 12,000 on the steers to get to 80,000 but you are actually limited by your tire and axle ratings, whichever is less.
    Upright, brian991219 and mitmaks Thank this.
  7. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    I run with 12,800-13,300 depending on fuel load regularly across scales all over the nation and have no issues. (Freightliner Cascadia) This gives you some lee-way on your other sets.
  8. mitmaks
    2,592
    2,113
    May 16, 2014
    Ok, door jamb says 12,000 but licensing tells me Im good to 12,500lb
    I know I have exemption due to APU I can be 400lb over gross but dont think it applies to axles being over.
  9. mitmaks
    2,592
    2,113
    May 16, 2014
    What is your front axle rated at? I know heavy haul trucks are rated over 14000lb on the front.
  10. Ridgeline
    22,760
    124,307
    My heavy hauls front axle are rated at 20k with a limit of 18k because of the tires.
    Dominick253 and okiedokie Thank this.
  11. MACK E-6
    50,192
    240,066
    Dump trucks run more than that.
