Front crank seal and possibly back.
Discussion in 'Ask An Owner Operator' started by feldsforever, Nov 30, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    What can I expect to spend to get this done. Is it safe to do at a T A?
    I have a shop I use near the house. But don't to go back in right now if I don't have to.
    2016 frieghtliner dd13
  3. bad-luck
    bad-luck Road Train Member
    3,435
    6,325
    Nov 16, 2013
    Baltimore, Maryland
    What seals are you referring to? Give a better explanation
    Rideandrepair Thanks this.
  4. AModelCat
    164,656
    I don't know if I'd trust a truckstop shop for front and rear crank seals.
  5. Elroythekid
    Elroythekid Road Train Member
    2,620
    5,674
    Sep 9, 2010
    Halifax Nova Scotia
    If your saying CRANK seals, HELL NO! Use a good engine shop familiar with your engine.
  6. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Don't trust TA petro they'll f I lt up
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    I did mean front crank seal. Sorry I posted on the way to bed.
  8. feldsforever
    1,453
    1,440
    Nov 22, 2019
    My local shop is 110 an hour. How long of a job is it?
  9. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Not familiar with the DD but it's most likely a pretty involved job. Transmission, clutch and flywheel of the back end and a bunch off the from as well
  10. Diesel Dave
    9,661
    32,720
    Jan 20, 2010
    Hesperia, Ca.
    It’s wise to have them go thru the whole transmission since it’s gonna be down. I good shop will be straight up if it needs bearings, synchros etc. It might not anything but seals. Depends on your pocket book, I myself would have them go thru everything, including clutch, rear main seal, motor mounts and the rear block seal if it has one. I’ve also had my transmission coolant lines and fuel lines replaced since it’s all easier to get to when the trans is down. But that’s me.
  11. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Pretty common leaks IMO. If they aren't creating a serious issue I would ignore them both and replace them when it's convenient like doing the rear if you have to drop the transmission. I certainly wouldn't trust a truckstop to do it either.
