Frozen tractor brakes
Discussion in 'Experienced Truckers' Advice' started by Drama304, Oct 26, 2020.
  1. Drama304
    Drama304 Bobtail Member
    11
    14
    Oct 26, 2020
    I’m stuck in Colorado. Woke up this morning and tractor brakes are frozen. I tried banging on them and put some air brake conditioner in the lines. No clue what to do next. Help please.
    Rideandrepair Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    77,753
    184,553
    Aug 28, 2011
    Henderson, NV & Orient
    Did you release the brakes before banging on them?
  4. Drama304
    11
    14
    Oct 26, 2020
    I did it while they were released and applied. No luck
    Rideandrepair and Chinatown Thank this.
  5. Lumper Humper
    2,081
    8,865
    Nov 23, 2018
    Pacific North Wet
    Might have to just keep banging on them
  6. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    Use a bigger hammer
  7. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Be sure trailer brakes are set, wheels chocked etc before crawling under truck to apply your magic. And...
    Your confident shoes are froze to drum and not water froze in system? Just a thought...
  8. Rideandrepair
    17,561
    56,895
    Aug 8, 2015
    Look inside the drums, chances are you’ll see ice blocks, on the bottom of the drum, against the shoes. If so, a propane torch to melt the ice works.
    Northeast Hillbilly and KB3MMX Thank this.
  9. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    I recommend carrying a wheel chock or two if you're going to be doing consistent winter driving. When you park for your 10 in cold weather set your brakes, get out and chock your tires then release your brakes.
    Shouldn't end up laying down in the snow and ice that way...
  10. upnorthwpg
    upnorthwpg Road Train Member
    1,829
    2,792
    Sep 23, 2011
    Yep. Never set your brakes right away after driving in snow. Since your done, you just need a bigger hammer. It always freezes at the bottom of the drum, bang there. You will know when they pop.
    bzinger, Rideandrepair, 062 and 2 others Thank this.
  11. supersnackbar
    20,108
    52,690
    Aug 19, 2007
    Your Town, USA
    If it's an automated tranny, it might not be the brakes but the grade gripper (that's what Mack called it). Had mine freeze last year even though I drain my tanks regularly. I also had my truck freeze to the ground that I had to fight as well. Went to bed it was warm enough to have slush, then it went thru freezing rain to snow and temps in the teens. Between the dump valve on my truck and the auto-deflating airbags when you set the trailer brakes I broke myself free. The O/O with an RGN next to me was still pounding his brakes when I was pulling out.
