Fuel lubricity additives
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bob Trehus, Dec 17, 2015.
  1. Bob Trehus
    Bob Trehus Light Load Member
    91
    73
    Nov 4, 2015
    I'm interested in thoughts about whether using additives is worth the expense, or is it nessesary when operating mechanical pump engines on ultra low sulfer fuel. If so... how to add a reasonably priced lubricity additive to my fuel program. Thanks for your input. Bob
    BoxCarKidd Thanks this.
  3. KAK
    KAK Medium Load Member
    518
    2,073
    Feb 10, 2012
    Ne
    Personally like the tc3 2 stroke oil from Wally world. Good lubrication and is designed to burn unlike regular motor oil. 1/2 gallon per side or so at fill up, then 1 quart or so per side every fill after initial start.
  4. Bob Trehus
    91
    73
    Nov 4, 2015
    I've heard this before... Makes better sense than cheap motor oil or ATF...
    Diesel Dave Thanks this.
  5. DUNE-T
    DUNE-T Road Train Member
    7,054
    17,193
    May 10, 2015
    Detroit, MI
    I just met a guy who brings his 1999 Volvo to the same mechanic as I do. He has 2 mil miles on his Detroit Series 60, that thing never has been overhauled or repaired, all original except turbo and he swears by Diesel Kleen, says he is using it every fill up and his overall mpg for the last 5 years is 8.5 mpg. I am gonna try that for a month and see what it does to my n14
    blairandgretchen, mp4694330 and KAK Thank this.
  6. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    I've heard of drivers using 2 cycle oil in fuel. Problem is it BURNS. Same thing with atf now you risk a chance of ruining injector over it.
  7. Flipflops
    Flipflops Heavy Load Member
    734
    966
    Oct 18, 2015
    A little bit of sugar can sweeten things up ;) lol
    rollin coal Thanks this.
  8. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    @KAK
    Here ya go. Old School Model T building motor machinist friend of mine turned me on to it years ago and I never looked back. $12 a gallon. Doesn't effect my DPF. Increases my performance/mileage for sure.
    There does seem to be a sweet spot with my EPA10 ISX however. It doesn't like too much. My old S60 Detroit I'm sure would have been happy running a 50:50 mix of the stuff.
    truckmaster9400, HalpinUout and SAR Thank this.
  9. blairandgretchen
    13,964
    76,789
    Dec 9, 2011
    South west Missouri
    01 N14, I use Schaeffers winter and summer additive.
    Guy I run with uses ATF on his big cam Cummins.
  10. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    It burns? So does diesel fuel the last time I checked.
    Low lubrictiy fuel can do more damage to an injector then the two stroke oil, the ratio is roughly a quart to 50 gallons of fuel for a decent mix.
    KAK Thanks this.
  11. SmokinCAT
    1,773
    1,488
    Oct 20, 2010
    ATF has specific additives for use in a transmission, it isn't designed to be burnt even though it will. Two stroke is.
    KAK Thanks this.
