Fuse box diagram 2003 Kenworth
Discussion in 'Kenworth Forum' started by kiddeasy33, Feb 17, 2015.
  1. kiddeasy33
    kiddeasy33 Bobtail Member
    7
    Hey y,all new to the Trucking business,and this Forum.I was wondering if anyone out there has a Fuse box diagram or owners manual for a 2003 Kenworth T600. Trying to locate the front marker lamp fuse. Thanks in advance!
  3. blairandgretchen
    14,019
    77,332
    Dec 9, 2011
    South west Missouri
    Wonder how similar the 01 T2000 is . . .
    You're talking about the glovebox location, right ?
    kiddeasy33 Thanks this.
  4. kiddeasy33
    7
    kick panel by the driver's left foot
  5. kiddeasy33
    7
    I'll try and post pics later, off to work...
  6. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    If by "front marker light" you mean the tri-angle shaped turn signals that are mounted right beside the head lights, they are NOT markers from the factory. They blink when turning only by design. If you want then to light up as a marker you will have to splice into the harness going to the little side marker on the bumper to get power. The factory harness is a 2 wire harness going to that light, you will have to change the socket and bulb from 1156 to 1157 even if you are changing to the LED conversions they come with a 1157 type connection. I hard wired mine but had non-stop problems after the second year, got tired of fixing it so put a brand new factory 2 wire harness back on it and went back to turn signal only.
  7. kwswan
    kwswan Road Train Member
    2,058
    11,380
    Jul 26, 2009
    mcminnville,tn.
    They could be ordered from the factory with a 3 wire function,my 03 t600 has it.
  8. kiddeasy33
    7
    Yep this truck has three wire harness and 1157 bulbs...
  9. kwswan
    2,058
    11,380
    Jul 26, 2009
    mcminnville,tn.
    There isn't a fuse just for those,they are on the same circuit as the corner lights on the bumper & your taillights.
    I can look in mine tomorrow if you want.
  10. kiddeasy33
    7
    Thanks, guess i'll be looking at the harness. all other lights work. this is what the fuse panel looks like. View attachment 79124
  11. kwswan
    2,058
    11,380
    Jul 26, 2009
    mcminnville,tn.
    Have you checked the bulbs to make sure they are good?
