Good decal adhesive remover
Discussion in 'Ask An Owner Operator' started by Stringb8n, Feb 13, 2023.
  1. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,232
    Sep 27, 2015
    What's good to use? Is there anything simple that you spray on and wipe off?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Heat gun and a plastic scraper. Just be careful don't use too much heat for too long. Should come off fairly easily.
  4. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    Goof off you can get it anywhere that sells hardware or paint
  5. Stringb8n
    1,705
    2,232
    Sep 27, 2015
    I'd have to find a heat gun. And hope my 1800 watt inverter will run it.
    Rideandrepair Thanks this.
  6. Chinatown
    Chinatown Road Train Member
    77,796
    184,729
    Aug 28, 2011
    Henderson, NV & Orient
    Cooking spray works on some adhesives.
    It even works on glue traps if a pet steps in one by mistake.
  7. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Different adhesives need different stuff. If it’s still soft, 3M adhesive remover, found at O’Reilly Auto Parts. If it’s hardened, an eraser wheel works better. You want a smooth wheel like my pic; not the one with notches in it.
    Don’t use a heat gun and plastic scraper. The heat gun will soften the paint making it very susceptible to being scratched. The scraper will scratch and potentially gouge the softened paint. Bad combination.
  8. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Just mineral spirits. It removes good and won't hurt paint
    Rideandrepair and ducnut Thank this.
  9. Concorde
    Concorde Road Train Member
    5,482
    19,492
    Jun 29, 2016
    West Melbourne Florida
    PB Blaster is absolutely incredible.
    Used it for removing the adhesive left behind from vinyl lettering.
    86scotty, Rideandrepair and ducnut Thank this.
  10. abyliks
    abyliks Road Train Member
    4,132
    9,731
    May 2, 2010
    ludlow MA
    Goo gone usually works, or our pin stripe guy says oven cleaner works if you still have everything intact
    I’ve got one of those erase wheels but I wouldn’t use that on anything nice paint
    Rideandrepair and kemosabi49 Thank this.
  11. rch10007
    rch10007 Medium Load Member
    560
    860
    May 26, 2007
    Madison, AL
