Good jacks, but bad driveway
Discussion in 'Road Stories' started by cornball, Apr 17, 2010.
  1. cornball
    cornball Bobtail Member
    7
    7
    Apr 14, 2010
    Knoxville, IA
    So, I recently had to get the radiator replaced in my International 9200 Day Cab - $1000, but that's a different story. In the meantime, I still had 2 contracts to fill for corn. I went ahead and hooked up my sleeper cab International 9200 and kept right on running my loads. When I finally got the call that the shop had my truck done, I was more than happy to switch back to my daycab - shorter wheel base, lighter truck weight, etc; so I ran out to the shop and picked my truck up. When I got back with it that night, I decided to switch tractors that night, so
    I could run with full loads again on the next day. I had already loaded my trailer, and had 60,000 lbs of corn on it.
    Well, I dropped my landing gear and pulled my sleeper cab tractor out from under the trailer, then went to go get the daycab tractor. When I got back, I realized that the jacks had sunk into the semi-soft gravel driveway about 2". Well, I kicked the jacks into low and cranked it up a few times, then started to back under. It was then that I realized that while the Sleeper Cab truck has lo pro tires, the day cab does not, and thus the frame sits about 4-5" higher... More cranking, sweating and cussing, until the jacks were fully extended and I was worn out. The dollies on the landing gear were now 3-4" into the gravel, and as I backed under the trailer, I realized that it was still not high enough... grumble, grumble.
    Got back in the truck, went back for the sleeper cab truck, brought it back and hooked up again, lifted the jacks, and then put 2x12's under the dollies, unhooked, got the daycab, and finally got hooked up right.
    I can haul about 50 bu. more with the daycab than the sleeper, so I was pretty happy to get it put on, but I have learned now that it is much easier to switch from daycab to sleeper than sleeper to daycab trucks for me.
    I am pretty thankful for gear reduction jack drives, though!
  3. kajidono
    kajidono Road Train Member
    6,422
    4,659
    Jun 1, 2009
    Streetrat
    I always put 4x4's under the jacks, pavement or not, loaded or not. That's 4" less to crank the jacks and I don't have worry about it sinking.
    cornball Thanks this.
  4. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Could have been worse. You could have said this is turning awfully easy to be lowering the legs... oh wait...:biggrin_2559:
  5. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    Did you try dumping the suspension before going through the trouble of re-hooking
    the sleeper cab??
  6. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    I was waiting for the part where the trailer would be too low for both trucks.
    Personally I would not have moved the sleeper out from under the trailer till I had the other truck in the dooryard. But hey thats just me.
  7. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    hmmm, this story sounds familiar, oh yeah, I've done it too. Not fun at all
  8. cornball
    7
    7
    Apr 14, 2010
    Knoxville, IA
    I always make sure that I dump my suspension, because it's just a little bit more that I don't have to crank!
  9. cornball
    7
    7
    Apr 14, 2010
    Knoxville, IA
    I was worried about that too when I was going to get my daycab again!
  10. Mr. PlumCrazy
    Mr. PlumCrazy Road Train Member
    1,341
    606
    Jul 30, 2009
    Lexington NC
    Yes it could have a lot worse like a Schneider did dropped his laoded trailer in front of stone container in the grass so he could go home for the weekend well when he went back the nose of the trailer was on the ground took a wrecker crew all day to get it out had to wait on the city to varfiy that there was no gas, water or power lines that could be damaged
