Grease on brake lines, what do you use to remove it.
Discussion in 'Ask An Owner Operator' started by JohnSmith69, Feb 20, 2026.
  1. JohnSmith69
    JohnSmith69 Light Load Member
    66
    30
    Feb 23, 2020
    Sorry if this is kind of a time waster but I get clumpy grease on my brake lines and I got a grease cleaning spray and it doesn’t work. What do you guys use to get clumpy grease off your brake lines? It’s ruining my clothes. TIA
  3. AModelCat
    164,712
    Hot water pressure washer
    JohnSmith69 and OldeSkool Thank this.
  4. abyliks
    abyliks Road Train Member
    4,123
    9,716
    May 2, 2010
    ludlow MA
    Simple green and steam pressure washer,
    JohnSmith69, OldeSkool and Opendeckin Thank this.
  5. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    Oven cleaner just before it rains .....
    JohnSmith69 and mtoo Thank this.
  6. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Brake cleaner and paper towel.
    Not sure how you’re getting grease on them, as they shouldn’t be hanging low enough to contact that part of the trailer nose.
  7. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    They sell really good degreaser at heavy duty truck parts store, I don’t remember the name of it off hand. It comes in a gallon, and it is reddish pink in color. It is really strong, so mix it with water in a spray bottle.
    JohnSmith69 Thanks this.
  8. rollin coal
    rollin coal Road Train Member
    13,623
    28,005
    Mar 29, 2008
    TN
    Probably "Mighty Boss" degreaser. It's made here in the USA in my hometown. I used it to wash motor oil off my tractor and trailer after a blown turbo gave it an oil bath. It's really good stuff works great.
    JohnSmith69 and Feedman Thank this.
  9. Diesel Dave
    9,675
    32,802
    Jan 20, 2010
    Hesperia, Ca.
    Starting fluid or WD-40 and a shop rag or old towel. Soaked the clothes and wipe off. Someone is over greasing for you to be getting all that sling.
    JohnSmith69, AFC, OldeSkool and 2 others Thank this.
  10. abyliks
    4,123
    9,716
    May 2, 2010
    ludlow MA
    maxi clean.
    Really good at taking everything off, including paint and polish….
  11. blairandgretchen
    13,936
    76,603
    Dec 9, 2011
    South west Missouri
