Harder to hit open docks?
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Oct 12, 2018.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    862
    1,636
    May 15, 2017
    Am I the only one who has this issue? I can back pretty well in tight areas, but when it comes to open docks I can't back for my life. Yesterday I had 4 open dock doors to back to ( had to hit the middle one ) and it took me about 5 minutes to get it. Meanwhile the reciever is standing with the door open with the disappointment look on his face.
    Such a weird phenomenon
    Take me to any dock in New Jersey and I can hit it better than an open dock....
    Wonder what it is about these open docks...
    alds and tinytim Thank this.
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    You’re missing a nearby reference point that is typically used imperceptibly by your brain to gauge your position and orientation in the dock area.
    tinytim, Digger130, JReding and 4 others Thank this.
  4. Clyde07
    Clyde07 Heavy Load Member
    809
    1,927
    May 28, 2013
    What STexan said. Plus, you always miss them when somebody is watching. If no one is paying attention, you can do it blind folded and no pull-ups.
  5. 25(2)+2
    18,756
    45,806
    Sep 18, 2006
    the road less travelled
    New pavement with no guidelines is tough, with worn pavement, you learn to follow the tire marks. After awhile. If it's expansion cut and filled concrete, sometimes you can line up with those lines.
  6. ButterDiesel
    ButterDiesel Bobtail Member
    12
    8
    Sep 16, 2018
    +3 If no one's paying attention, I'm a backing GOD. One person, or worse yet, a coworker, and they get a big kick out of my ineptitude lol
    alds and JReding Thank this.
  7. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    Must be two kinds of open docks, it doesn't get easier than having no obstacles in the way. The dock is square and the trailer is square, can't get much simpler than that.
    Canadianhauler21 Thanks this.
  8. Moose1958
    Moose1958 Road Train Member
    15,266
    33,855
    Dec 17, 2010
    Williesburg, Virignia
    Sounds tacky I know, but I know of some drivers that will pull out 2 cones and set them up about 10 feet from the door. Gives them a point of reference. I never did that, but at night I did use flashlights.
  9. Moose1958
    15,266
    33,855
    Dec 17, 2010
    I agree with you if there are lines drawn. I have had trouble hitting a dock square with no point of reference.
  10. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    My last job had crooked lines at their terminal. It drove everybody completely crazy. One driver finally had enough and went out with black paint and a roller and painted over them. The owner had to fix them after that. Everybody was much happier.
    Canadianhauler21 and STexan Thank this.
  11. jgarciajr40
    jgarciajr40 Medium Load Member
    673
    977
    Jun 18, 2016
    I find it harder to dock when there no lines, or any other trailers in the yard. I've literally gone out and put a wheel choke on the ground to mark a spot. I've also noticed if you use the concrete joints when there's no line it helps.
    I'm of course talking about non-traditional docks.
    Paddlewagon and Canadianhauler21 Thank this.
