Heavy vibration when I turn on engine brake
Discussion in 'Ask An Owner Operator' started by Moephilly1, Jan 12, 2019.
  1. Moephilly1
    Moephilly1 Light Load Member
    111
    35
    Oct 6, 2016
    hey guys I have a 2007 w900 with cat 15, when I turn on engine brake The whole truck and engine starts to vibrate heavy and the check engine light comes on sometime but goes fast I can’t figure out the flash code. Any thoughts? Thanks
    Dale thompson Thanks this.
  3. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
  4. D.Tibbitt
    157,285
    Thats ur truck sayin "quit slowin me down driver!!!"
  5. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    VV-heads? Chances are they are busted, crack the valve covers and check.
    Moephilly1 Thanks this.
  6. supersnackbar
    20,167
    53,155
    Aug 19, 2007
    Your Town, USA
    I'm not familiar with CAT's, but if it has selector switch for low/med/high, see if it does it on each position. It'll help identify which cylinder(s) are the problem.
    Tombstone69, 22dragoo and Moephilly1 Thank this.
  7. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    STAY OFF THE JAKE. Until you can take a peak into the rocker boxes. When is the last time you ran the Rack on your motor? If it has been awhile then you got one or two out of adjustment. If Trk is shuttering bad then do valve adjustment and re-bush jakes. Check number 3-4 cylinder first, they usually go before others. You’ll be fine as long as you don’t keep riding around singing the jake. Also check springs, a busted jake spring will cause vibration. Problem will reveal itself as soon as you look in the rocker boxes.
  8. Moephilly1
    111
    35
    Oct 6, 2016
    I turn it on once a week, I’m not the type of driver who has it on 24/7
    D.Tibbitt Thanks this.
  9. Moephilly1
    111
    35
    Oct 6, 2016
    I dont usually use it it’s once in a blue when I really need it. I recently bought the truck so I’m not sure about that. I’ll take it to a shop Monday to check that out that’s for your help
  10. Moephilly1
    111
    35
    Oct 6, 2016
    Will do thanks for the help
  11. Moephilly1
    111
    35
    Oct 6, 2016
    It does it on all positions
