Help backing spread axle 45 degree and 90
Discussion in 'Flatbed Trucking Forum' started by PeterbiltPaul, Feb 13, 2021.
  1. PeterbiltPaul
    PeterbiltPaul Bobtail Member
    4
    Any advice how to set up
  3. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    Same as a tandem. Then watch as the spread constantly changes it's mind on which axle to pivot on. And 90* driving forward or backing loaded, you get to experience tearing up your spindles and trailer frame.
    If you want to predict it's path, and save your tires and running gear, put a dump valve on the rear axle.
    snowman1980, MOBee, booley and 10 others Thank this.
  4. Chinatown
    Chinatown Road Train Member
    77,753
    184,595
    Aug 28, 2011
    Henderson, NV & Orient
    Right, makes getting into a tight spot simple.
  5. PeterbiltPaul
    4
    It seems the tires slide more then roll on the trailer I've set up just like tandem but my trailer always seem to be to far back when I start
  6. PeterbiltPaul
    4
  7. PeterbiltPaul
    4
    Yeah and trailer is my company what's a dump valve
  8. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    A valve that dumps the rear bags. Wire it to a switch on your dash. Puts the weight on the front axle. Now you can pivot on the front, and trailer behaves like a 38 footer.
  9. 201
    201 Road Train Member
    12,787
    26,313
    Apr 16, 2014
    high plains colorado
    Oh, boy,,,okay, that's entirely possible. The "dump" valve lets air out of one of the spread axles, so the tires don't drag. It's more of an O/O thing, and companies rarely have that option. My advice, when you get perpendicular to the dock, as close to the other trailers fronts, make a gradual radius, more than a regular tandem, if there's room, of course. You're going to grind the tires off no matter what, without a valve.
  10. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    With my spread axle, I try to never lose sight of in my mirror when turning/backing. If I have lost it in the mirror, I know I'm putting massive stress on the forward spread axle and shredding the tires.
    So my advice is to set up with as straight as possible back as you can. Otherwise you are going to cost your boss a ton of money in tires and trailer alignments.
  11. F4T6UY
    F4T6UY Medium Load Member
    567
    1,807
    Oct 24, 2017
    Very South Texas
    But if you have a dump valve, and you are heavy, what are you doing to that forward axle as far as wear and tear or worse?
    I’ve no experience with spread axle, so I’m curious as to the benefits/downsides of a dump as well. Sometimes 90 degree is inevitable.
