Help!! Driver is saying he is overweight.
Discussion in 'Refrigerated Trucking Forum' started by jjpaez123, Dec 16, 2017.
  1. jjpaez123
    jjpaez123 Bobtail Member
    24
    11
    Dec 26, 2014
    could you please let me know what's the total weight overweight to determine how many pallets need to removed ?
    Steer weight: 11540 lb
    Drive weight: 28520 lb
    Trailer weight: 37240 lb
    Gross weight: 77300 lb
    Trailer is going to Pennsylvania.
    Thank you!!!
  3. tinytim
    tinytim Road Train Member
    5,145
    19,378
    Oct 29, 2007
    Northern Ontario
    Well, first off I hope nobody thinks about opening that pdf.
    The 3 weights listed don't add up to 77300.
    Remove 2.4 pallets.
    peterd Thanks this.
  4. jjpaez123
    24
    11
    Dec 26, 2014
  5. jjpaez123
    24
    11
    Dec 26, 2014
    sorry I listed the wrong quantities.
    steer weight 11540
    driver weight 28520
    trailer wight 37240
    gross weight 77300
  6. tinytim
    5,145
    19,378
    Oct 29, 2007
    Northern Ontario
    Trailer weight, 37240.
    You need to transfer some of that weight to bring the trailer weight down to 34000 or less while keeping the drives below 34000.
    You may be able to slide the tandems forward to move some of the weight to the drives but probably need to redistribute what's in the trailer.
    The overall weight is fine but it's not distributed properly.
    jjpaez123 Thanks this.
  7. arrogant steve
    arrogant steve Medium Load Member
    444
    463
    Mar 31, 2016
    East Texas
    What hole are the trailer tandems in? He may be able to slide them forward enough to get legal. He also has some wiggle room on 5th Wheel.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    He would have to take his 3240 pounds or more off his trailer, that means the tandems need to be slide backwards under the trailer. Its either 500, 750 or 1000 per hole. Call it 4 holes back to start, weigh again. And confirm the trailer is under 34000.
    Here is a twist. The position of the trailer tandems cannot be beyond the 48 foot line of a 53 foot trailer. And in California and some states even shorter wheelbase demands.
    Worst case scenario, have them take off two pallets. That's at least 4000 pounds. If they are small pallets, take off 4 from the back.
    I did not open that pdf.
    bigkev1115 and p608 Thank this.
  9. arrogant steve
    444
    463
    Mar 31, 2016
    East Texas
    Sorry, I meant to say slide tandems back and not forward.
  10. tinytim
    5,145
    19,378
    Oct 29, 2007
    Northern Ontario
    Me too.
    x1Heavy and jjpaez123 Thank this.
  11. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    If we're talking about a 53 foot trailer, generally speaking the load should not come past about the 48 foot mark [if it's a "heavy commodity"]. My guess is the cargo is loaded all the way to the back and the driver doesn't want to run with the trailer tandems all the way to the back [to keep the weight better distributed]
    Such a situation can typically be remedied by stacking product cases higher and using fewer pallets to keep the cargo (pallet) footprint length to around 48 feet instead of 52 feet.
    In your post, there seems to be nothing wrong with the amount product added. It seems to be more of a "distribution problem" if it's loaded back to very near the doors of a 53 foot trailer.
    If this is the case, chances are the driver could have made the weight good, but in doing so would have been "too long" and it's never a good idea to drive around with the tandems all the way back. (Too hard to negotiate tight turns)
    Farmerbob1 Thanks this.
