Help For New Company
Discussion in 'Ask An Owner Operator' started by Assyrian, Jul 19, 2021.
  1. Assyrian
    Assyrian Bobtail Member
    14
    Chicago, IL
    Hi for every one !
    i just got my Authority and only me i will run my company so no other driver or Owner Operator !
    i sign with keep trucking for ELD and i receive it and i did new Annual inspection for my truck under my dot number ,
    plus i sign with dot for load board , but same one told me i need to do before i start pickup and dlv load to do
    register for
    DOT Clearinghouse Services
    DOT Drug & Alcohol Compliance and drug Test
    Driver Qualification Files
    MVR Monitoring – Motor Vehicle Record Monitoring
    DOT Audit
    so can i get help i don't from where i should be start ?
  3. Judge
    92,308
    Www.ooida.com
    Audit comes later, like 6-9 months in to be sure you keep with with logs, Maintence, driver qualification file.
    They’ll get it all done, gotta be in a drug testing random pull too, Ooida has that through cmci.
    drivinhome and Dave_in_AZ Thank this.
  4. Crassius
    Crassius Light Load Member
    87
    121
    May 15, 2013
    ProfessionalNoticer above posted an excellent resource that has everything you need to do... all you have to do is follow it... if you are comfortable doing everything yourself. Only you can be sure of that.
    Although I own a great Stihl chainsaw, cut and chop my own firewood, I don't cut down large trees. Its not rocket science, I could learn how to do it if I had the right teacher, but the risks are high, and my comfort level at that high risk level makes me wait for mother nature to lay them on the ground for me.
    If you read through the above posted eBook, mabe even start doing the steps and find you are not comfortable and don't want to expose yourself to risk, OOIDA can help you... for a fee. Only you can decide if the fee is worth avoiding the risk to you.
    Applying for Authority - OOIDA
  5. Ridgeline
    22,732
    123,557
    Just join ooida, work with them, they will guide you.
    drivinhome Thanks this.
  6. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    You need to do a drug test before you haul a load. Someone I know got wacked , for that.
    ProfessionalNoticer Thanks this.
  7. drivinhome
    drivinhome Light Load Member
    91
    102
    Sep 16, 2009
    Southeastern Mass
    OOIDA. About $800 and they will take care of everything. Best way to go.
  8. Big Road Skateboard
    7,118
    40,410
    May 2, 2021
    Don't think so, I haven't anyhow. Just need to be in the consortium. I've been wrong about things once before though.
  9. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Pre employment drug test
    Big Road Skateboard Thanks this.
  10. Big Road Skateboard
    7,118
    40,410
    May 2, 2021
    Gotcha, but owner ops don't. Correct?
