Help - Reefer not cooling after first cycle (start/stop)
Discussion in 'Refrigerated Trucking Forum' started by hmpfletes, Sep 27, 2022.
  1. hmpfletes
    hmpfletes Bobtail Member
    5
    Mar 22, 2022
    Amps 2.7, unit running
    Amps 0.8, unit stopped
    Volts 13.7, unit running
    Volts 13.0, unit stopped
  3. reeferwrencher
    reeferwrencher Medium Load Member
    618
    1,577
    Aug 4, 2018
    That's good.Can you check the 3 way valve when the problem occurs?When it's on cool the pipe off the valve going to the back wall shouldn't be hot.You could also run it through an auto pre trip.
