Help - Reefer Won’t Quite Reach Set Point
Discussion in 'Refrigerated Trucking Forum' started by SoCalKid, Jul 11, 2022.
  1. SoCalKid
    SoCalKid Bobtail Member
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    Hey Guys and Gals,
    I’m having an issue with my reefer trailer and was hoping y’all might be able to point me in the right direction.
    The past couple of weeks I’ve had a couple loads where the BOL said to set the temp to 34, and my trailer constantly stays right around 36. It occasionally touches 34-35, but for the most part it stays at 36. The part that is troubling me is that I’ve also had some -10 frozen loads in between the 34 degree loads, and on those loads the reefer was able to maintain -10 in the Phoenix heat no problem. So I don’t have the slightest clue why it isn’t maintaining 34 degrees.
    The unit is a 2013 Thermo King SB-330 on a 2013 53’ Great Dane trailer. I just replaced my belts as one was cracking, but this issue was occurring both before and after the belt replacement. The computer isn’t throwing any codes either.
    Does anyone have any ideas why this might be happening?
    Thank you all!!
  3. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Most likely it's the heat of the load. Not an issue with the reefer.
    dunchues, motocross25 and SoCalKid Thank this.
  4. motocross25
    motocross25 Road Train Member
    3,906
    12,038
    Sep 23, 2010
    Overland Park, KS
    Do you have it set in cycle or continuous? I’ve heard some units are programmed when they are set that close to 32 to kind of “buffer” the temperature so it’s not blasting freezing air over something delicate like leafy greens or berries when it kicks on. @Wasted Thyme is probably right tho it very well could be the core temp of the product.
    SoCalKid Thanks this.
  5. SoCalKid
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    Both loads have been continuous. Prior to noticing the issue, I had a 34 degree cycle load that reached the set point no problem.
    Additionally, I saw somewhere on the forum about checking for gunked up lines. I just massaged the line underneath the unit that released the defrost water and a big chunk of something shot out followed by a bunch of water. Not sure if this could’ve been causing my issue, but will continue to monitor the situation.
    Thank you both for the timely responses!!
    motocross25 Thanks this.
  6. wichris
    wichris Road Train Member
    4,572
    9,422
    Jan 17, 2011
    What's the product?
  7. SoCalKid
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    The first load I noticed it on was Yogurt. The current load is Almond Milk.
  8. wichris
    4,572
    9,422
    Jan 17, 2011
    If you're running it in the dock while loading do a manual defrost. The condenser partially freezes it will hurt. What's the RA? If you're putting 34 degree air in and the RA is 36-38 the product is warm.
  9. bad-luck
    bad-luck Road Train Member
    3,498
    6,472
    Nov 16, 2013
    Baltimore, Maryland
    What was the product you were hauling at 34?
  10. bad-luck
    3,498
    6,472
    Nov 16, 2013
    Baltimore, Maryland
    Sorry I missed what the product was. I would get it checked out. Both yogurt and milk are always pre cooled before loading. There is a temperature sensor in the nose of the trailer, I have had one that was started to go bad before.
  11. reeferwrencher
    reeferwrencher Medium Load Member
    622
    1,584
    Aug 4, 2018
    The unit goes into modulation mode on continuous when it nears setpoint.As was stated earlier,its to maintain setpoint without freezing the coil therefore it shouldn't need to be defrosted all the time and lose all moisture in the box.You might have a problem with that,but if the drain hoses were plugged that is most likely the cause.
