Help
Discussion in 'Freightliner Forum' started by tomfish86, Jul 22, 2019.
  1. tomfish86
    tomfish86 Bobtail Member
    My truck is Freightliner cascadia 2016 DD15 engine. I was sleeping when the engine shut off by itself and now it's showing a yellow solid check engine and Regen sign with EEC 61 Code what should I do? please help me.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Probably just need to do a Regen. Put it in neutral, press and hold the Regen switch for about five seconds. It should pick up rpms, sound like its running rough for 20 - 40 minutes, then idle back down when complete.
    rebs Thanks this.
  5. D.Tibbitt
    156,846
    U need to do regen. It probably needed regen while u were sleeping but since u were sleeping u couldnt activate it.. The regen symbol It starts flashing at u if u ignore the solid light and if u ignore the flashing light it will throw the code until u regen . once regen is done it should clear the code.
    rebs Thanks this.
