Help
Discussion in 'Ask An Owner Operator' started by Ladytrukr, Sep 21, 2017.
  1. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    It's called cutting your losses. Alternately you can throw good money after bad until you have none left....
  3. Ridgeline
    22,750
    123,956
    So what if you paid $400 for an ignition repair, you should have ordered the cap for the WW fluid as soon as you knew about it, had the FE replaced by the driver so she was legal and get the fifth wheel repaired or replace before you accepted any load. Tires and logs are on your driver, he/she should have told you that the tire was bald and had her stop and get those which are marginal replaced.
    Have your driver do a good pre-trip and write down everything that needs replacing, and then have the take pictured of those items and send them all to you.
    Remember these three important things about mitigating these problems -
    1 - the driver is your eyes and ears, if you trust them to drive, then you should trust them to tell you when there is an issue with the truck - if not get rid of them and get another driver.
    2 - this is a business, it takes money to maintain the truck, and if you have no maintenance fund to pull money out of, then you need to restructure your ledger and put money into it and spend the money - do not be cheap. From your comment about spending $400 on an ignition repair, it sounds like you are cheap.
    3 - the real purpose of an inspection is to find these issues, be it a road side level one or a DOT annual. I as a owner/operator told those doing an inspection that I want them to find things wrong so a road side won't. As a fleet owner, I really drive that point home with some of these mechanics that we use regularly. I depend on them to do their job so I don't get dinged with violations, so you should to so maybe getting a bi-annual or better yet a quarterly inspection by a mechanic who will be honest about finding crap should be a goal.
  4. blairandgretchen
    13,981
    76,904
    Dec 9, 2011
    South west Missouri
    This - absolutely
    And this, but it won't alleviate 4600 lbs over on drives (where are trailer tandems at?!),
    I figured the coiled hose to slides was the culprit -, but moot point.
    Ex-Prime driver - forget it. It's a puppy mill.
    Good luck - but remember your actions as a business owner reflects upon us all.
    Ladytrukr Thanks this.
  5. m16ty
    m16ty Road Train Member
    2,274
    4,964
    Jan 22, 2016
    With those violations, I'd say you got off cheap and no "out of service".
    I wonder if the inspector just commented that the tire was getting too worn but wasn't technically out of spec. I thought a tire out of spec was a automatic OOS?
    Ladytrukr and Mike2633 Thank this.
  6. blairandgretchen
    13,981
    76,904
    Dec 9, 2011
    South west Missouri
    Yes. But I think we all know the minimums.
    If we're running around on borderline tread depths, then surely there's s hole in our business plans that needs addressing?
    fordconvert Thanks this.
  7. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    On you
    1)If u seen truck Monday, tires don't go bald in 4 days unless there is a major problem.
    2) washer cap.. you knew it was gone
    3) extinguisher- again you knew it was used and needed another one.. not driver job to buy your truck supplies unless there is a system to reimburse
    4) you hired a prime rookie, gonna have some bumps and bruises along the way, that's why they come cheap.
    Drivers no no
    1) over weight, can't move 4600 with fifth wheel so tandems were wrong to.
    2) log book, if came from prime probaly was never even shown how to run paper.
    Pay you fines, take your lumps and bruises and BOTH of you learn from your mistakes. lucky you wasn't out of service. Issues on both ends here and atleast your driver has a excuse of being a rookie. Good luck..
  8. IluvCATS
    IluvCATS Road Train Member
    4,089
    8,973
    Dec 1, 2014
    Seattle, WA
    Thanks but no thanks for your opinion. o_O
    Knucklehead Thanks this.
  9. m16ty
    2,274
    4,964
    Jan 22, 2016
    I just did a little research. According to the regulations, 3/32 on a steer and 1/32 on other tires will be a citation but won't be OOS.
    I thought any tire violation was a auto OOS, but looks like I was wrong. One thing we do is run good tires so I've never had experience with a tread depth issue.
  10. RStewart
    RStewart Road Train Member
    3,172
    5,073
    Aug 21, 2015
    Norman, OK
    This guy will probably keep you behind but I hope not.
    What's this? I've never taken one in 20 years.
  11. Joes fat
    Joes fat Bobtail Member
    5
    Dec 27, 2015
    I do raise the hood at least once a nth whether it needs it or not duh
