High pitched squeal/whistle under high boost
Discussion in 'International Forum' started by 2013Maxx, Apr 21, 2021.
  1. 2013Maxx
    2013Maxx Light Load Member
    137
    42
    Jan 17, 2018
    Hello, I’m getting a high pitched squeal/whistle from the turbo area under high boost/load.. Truck has 531k on the odometer. Anyone know what it can be? 2013 ProStar Maxxforce 13
  3. Judge
    92,768
    Could be something as small as a pinhole in the air to air.
    Loose clamp.
    Something of that sort.
    beastr123 Thanks this.
  4. 2013Maxx
    137
    42
    Jan 17, 2018
    I sure hope so.. Do you know what the OEM target boost is?
  5. Judge
    92,768
    Never run a MaxxForce, just experience from whistling noise under boost
    2013Maxx and Bean Jr. Thank this.
  6. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Should be around 43psi. Check for exhaust leaks, any signs of soot, can cause a whistle. Rear manifold is a suspect spot. Best bet is to use a smoke machine, every dealer should have one.
    2013Maxx Thanks this.
  7. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    I get that on my Maxxforce all the time.
    Have yet to figure out what it is.
  8. 2013Maxx
    137
    42
    Jan 17, 2018
    The tube from the turbo to the intercooler was loose. It’s held on by two metal rings thats lost its clamping force. I put two cheap hose clamps on it for now and it’s gotten much better. I’m gonna put some T clamps on it for a good air tight seal soon as I get some off time.
    Judge Thanks this.
  9. bonder45
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    I just want to say, I've had my MaxxForce for 3 years now and she's been a good truck.....
    IIIFFFFFFF you do regular services and don't idle it.
  10. ChuckMartel
    160
    94
    Jan 22, 2021
    definitely get the spring loaded CAC clamps.
