Highest RPMs should go?
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, May 15, 2020.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    I was going down a huge mountain and accidentally let my RPMs get up to 2700. What is the highest RPMs can go without damaging anything?
    singlescrewshaker Thanks this.
  3. WesternPlains
    6,369
    57,407
    Sep 1, 2017
    Rapid City, SD
    You risk blowing the turbo charger. Should stay below 2000.
    Jdm5jdm5 Thanks this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    What engine, makes all the difference.
    okiedokie, MACK E-6, D.Tibbitt and 2 others Thank this.
  5. Jdm5jdm5
    193
    60
    Apr 13, 2016
    DD15
    D.Tibbitt and singlescrewshaker Thank this.
  6. singlescrewshaker
    4,880
    42,752
    Dec 31, 2017
    Little Havana, FL
    Depends on the engine. Should say on the valve cover max rpm..
    Mines only an 1800rpm max, 1925NL.
    If the Jake's won't hold her back by 1925, I press the service brake & bring her down 7-9mph & repeat till I'm safely off the grade..
    Brettj3876, Hulld, Doealex and 2 others Thank this.
  7. D.Tibbitt
    157,285
    Accidently ? How does that happen ? Must be an automatic or u would know u was in to low of a gear
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Yeah I wouldn't do that again.
  9. AModelCat
    164,924
    Typically on a large, 12-15L diesel you don't really want to get above 2,100 to 2,200 RPM.
    Did 2,700 hurt it? Probably not. Issue with overspeeding is you start to see "valve float" at high speeds. The valve springs can't get the valve closed in time. You risk major valve train damage and a piston can smack a valve.
    Then you add in the inertia of the pistons going from dead stop to full speed extremely rapidly. Very easy to throw a rod.
    You've got the flywheel and clutch housing to worry about as well.
  10. AModelCat
    164,924
    If any of you are interested in seeing the carnage on the valvetrain from an overspeed, check out this recent thread:
    Click Click Boom!!!!!
  11. MGE Dawn
    MGE Dawn Road Train Member
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    Not even. There are ways to force a DT12 into a gear that much lower than you should be in, but they're all quite intentional... and also not worth the effort to pull them off, either. Better off stabbing the brakes and praying IMHO
    Jdm5jdm5 and D.Tibbitt Thank this.
