Holy puck this #### Kenworth
Discussion in 'Ask An Owner Operator' started by trips74, May 13, 2023.
  1. trips74
    trips74 Medium Load Member
    367
    217
    Nov 7, 2007
    chicagoland, il
    So after rebuild they say turbo is bad, they replace turbo and actuator, then they say it still running bad. They remove exhaust from turbo and says running fine, so know there inspecting the def filter, which if you ask me was probably the main issue the whole time lol.
    But if I ever get my truck back I'm gonna have lots of new parts.....
    LoneRanger, Dave_in_AZ and ducnut Thank this.
  3. Siinman
    Siinman Road Train Member
    5,522
    14,206
    Mar 5, 2017
    Kansas City, MO.
    Should had got a Volvo!
    86scotty Thanks this.
  4. Dave_in_AZ
    425,460
    Which shop?
    Which engine?
    Siinman Thanks this.
  5. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Get rid of that POS and won't be stuck at shops anymore
  6. Ridgeline
    22,727
    123,478
    Didn't they put it on the computer to see what the back pressure is or at least check it before replacing the turbo?
    Magoo1968 and Siinman Thank this.
  7. Cdemars316
    Cdemars316 Road Train Member
    1,037
    6,713
    Nov 10, 2018
    I have seen just as many of those be a huge POS as I have Paccar, they may have there #### straight now but from about 2011 to about 2018 they were the worst of the worst for emission issues. I am no fan of new Paccar crap.
    Reason for edit: insult removed
  8. Siinman
    5,522
    14,206
    Mar 5, 2017
    Kansas City, MO.
    Depends on the spec. All trucks are crap with emissions when spec'd wrong.
  9. AModelCat
    164,807
    Seems like the harder the engine works, the less issues they have. With most of today's 13L engines putting out power similar to the 15L engines of 20 years ago there's little reason to spec anything more than a 13L for general freight.
    ducnut, Long FLD and rollin coal Thank this.
  10. Siinman
    5,522
    14,206
    Mar 5, 2017
    Kansas City, MO.
    Lower RPM is where Volvo engines like it. They need to keep the heat in the engine. Running high RPM's causes most of the problems. So if they have low gears they tend to have more issues with emissions.
    rollin coal Thanks this.
  11. trips74
    367
    217
    Nov 7, 2007
    chicagoland, il
    I don't think they know how to read there computer, of course they've had it on the computer, numerous of times at this point though I don't trust these peons with a crescent wrench. But hopefully truck will be right sometime this week
    Dave_in_AZ Thanks this.
