Home Made Top bunk for my truck?
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Apr 5, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    Out of all the things I need a top bunk is high on my priority list. But they all seem to be about 650 or better.
    Have any of you made a good home made one that you trust?
  3. blairandgretchen
    14,053
    77,642
    Dec 9, 2011
    South west Missouri
    Is that dealer or wrecker yard price?
  4. EvergreenTrucking
    EvergreenTrucking Bobtail Member
    8
    8
    Apr 6, 2022
    Never, but if you’re dealing with single wall cab steel then I would use appropriate fasteners from the outside in. Stainless, and/ or pre painted Tapcons drilled into angle iron inside the cab acting as a ledge. Then run cross square tube metal to support painted 3/4” plywood
  5. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Dealer, I never thought about the other thanks for the lead.
    Rideandrepair Thanks this.
  6. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Nice thank you.
  7. Siinman
    Siinman Road Train Member
    5,583
    14,372
    Mar 5, 2017
    Kansas City, MO.
    Vanderhaag might be a good place to find used wrecked.
  8. Rideandrepair
    17,606
    57,001
    Aug 8, 2015
    I put one in my last Classic from a Century, for $100 at the junkyard. I had to take it out myself. Dealer wanted $1,000 for just the bunk. Most junkyards were too expensive. It pretty much bolted in, had to take interior panel off and install the 2 brackets or ears for it to sit on. The rear hinge sits on the existing corners, bolts in. I didn’t install the latches for holding it in an up position. That was a bit complicated. Just left it down all the time. I need a shelf now, in my current Classic, not so much a bunk. My neighbors got a parts Truck now. I’m debating on getting the bunk from it. Whatever you do, you probably have existing holes already for a factory bunk. Once you take the panels off you’ll see them, along with the steel or aluminum 1.5”x1.5” framing for the bunk. Getting a big piece of plywood in, might have to take passengers seat out. I’d like to get an old dairy shelf rack, or a plant rack. The type you see behind grocery stores or Home Depot. Starting with that, and reinforce as needed.
