Hook for Headset
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by madmoneymike5, Jun 5, 2020.
  1. madmoneymike5
    madmoneymike5 Medium Load Member
    633
    283
    Jan 30, 2010
    Arlington, TX
    I use a Blue Parrot B350. It's so lightweight and the head band so flexible that even some of the smaller bumps are able to get it airborne high enough to fall off my generic 3M command hook.
    I need something where the hook part is taller so it can't get high enough to fly off OR I need some way to steady it so it doesn't bounce and sway quite so much.
    Any suggestions?
    D.Tibbitt Thanks this.
  3. T.Rucker
    T.Rucker Medium Load Member
    414
    1,018
    Jul 31, 2015
    Here and there…
    It’s not pretty, but I use a wire coat hanger. Cut it down to the size I need and bend it so it has a big hook so my headset won’t bounce out it. Used it for a couple years, works great.
    NavigatorWife and D.Tibbitt Thank this.
  4. Zues
    Zues Bobtail Member
    47
    26
    Apr 22, 2020
    Good idea thank you
  5. Judge
    92,095
    I hang mine off passenger side armrest...
    bad-luck and NavigatorWife Thank this.
  6. madmoneymike5
    633
    283
    Jan 30, 2010
    Arlington, TX
    Thanks for the responses, folks! My thoughts on each suggestion follows...
    I was looking for something a little cleaner. I've gone way out of my way to make sure my cøckpit looks clean and professional as possible.
    But I do have those flexible rubber wire ties. Not super stoked about that idea, but if all else fails...?
    My CB microphone cable doesn't make the same "loop" yours does, probably because I have my radio on the dash.
    I have a thermoelectric cooler sitting in the passenger seat. Barely fits between the arm rests. I can't really even move the arm rests all that easily. I've tried my own arm rest before; it broke my last headset (same 350xt) because of strain on the part where the plastic meets the metal of the headband--the plastic cracked and allowed the headband to fall off.
    There was once a product I saw in a truck stop but can't find now. It was a headset hanger. Any ideas?
    NavigatorWife Thanks this.
  7. Judge
    92,095
    besides my catch all, just my notebooks ride in dummy seat
  8. Finfn1372
    Finfn1372 Road Train Member
    1,930
    3,599
    Aug 7, 2014
    Greenville,NC
  9. ragtopjr
    ragtopjr Light Load Member
    151
    50
    May 14, 2008
    Saskatoon,Sk,Can
    I use this hook mounted to the bottom of the upper dash (above the windshield) it will sway but you really have to hit a serious bump for it to pop out...
    Hookster (black)
  10. bad-luck
    bad-luck Road Train Member
    3,438
    6,331
    Nov 16, 2013
    Baltimore, Maryland
    Us that horny goat weed in those bottles in the pouch?
