hot to the touch drop axle, need help!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TowHaul, Aug 1, 2021.
  1. TowHaul
    TowHaul Medium Load Member
    416
    79
    Mar 7, 2016
    I have one of my two drop axles very hot to the touch. I am not sure if it is due to a bad wheel seal (mechanic said the inner wheel seal was leaking...but it had oil in it the entire trip) or a bad slack adjuster holding up the brake (this has happened before), or too much pressure applied to the axle from the control. I am definately concerned and would like to address this before it becomes a major issue. However I do not want to throw parts at it. Mechanic months ago said it had a leaking inner wheel seal, but other than old dried crud on the brakes I am not seeing fresh oil (after topping off the hub) and it seems to be holding the oil i put in. I did back off the brakes and it seemed to have been cooler. Then i adjusted the slack adjuster back to the proper setting and the wheel seemed hot again. I was also told that I might be applying too much pressure to the drop axle and that would cause the heat issue, but the problem seems much more noticable on the one axle (both are a noticably hot compared to the other rims/hubs). Any advice before I have a mechanic throw parts at it that likely wont fix it... Also after adjusting the slack back to what i believe to be the proper setting the truck did roll on its own in neutral so i assumed i had the brakes adjusted right(?). I'm leaning towards a bad bearing (wheel does spin), or bad slack adjuster?, or who knows what else.... i'm really not a mehcanic
  3. Cattleman84
    Cattleman84 Road Train Member
    10,022
    71,569
    Nov 1, 2017
    The Sticks, Idaho
    Were it me I would start with new bearings and seals for that entire wheel end... And probably new brakes.
    Bean Jr. Thanks this.
  4. TowHaul
    416
    79
    Mar 7, 2016
    ya thats what i'm trying to avoid. rather just fix whatever the specific problem is. Trying to find a way to narrow down the problem.
  5. Judge
    92,404
    As my old boss would say and I’m quoting him, “Don’t touch it, it’s hot. Keep driving it and it’ll show itself, eventually.”
  6. TowHaul
    416
    79
    Mar 7, 2016
    i dont know if i should laugh or get nervous reading that advice! :) Hot is a warning before massive problems begin is my montra.
    hard part i'm having with the diagnosis is that the wheel in the up position will not spin as its hitting the bottom of my bed. so i have to run around the truck once i put the axle in the up position to quick test it for spin (it does spin... or at least *did spin once i dramatically backed off the slack adjuster.... i have since readjusted it back to where i thought spec should be).
  7. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    Just out of curiosity, what are you using as ‘hub oil’?
  8. roundhouse
    roundhouse Road Train Member
    3,213
    7,334
    Jul 11, 2018
    Do you have a air pressure gauge on the drop axle bags ?
  9. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    1st you may have a bad auto. brake adj. If you have all/ready backed it off 1 time and its too tight for the 2ed time its a bad brake adj. A wheel seal that was leaking is still leaking and needs to be replaced, ck. the slop in the wheel bearings with the brake backed off and that wheel jacked up?
  10. TowHaul
    416
    79
    Mar 7, 2016
    "bad brake adj" that is something I had not considered. is that expensive part and difficult to replace? the rim/wheel did seem less hot after i dramatically backed off the slack ...sooo perhaps it readjusted itself back to a problematic adjustment?
  11. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    A bad bearing will not stay bad long, it will fail. My guess is over load, take it to a scale when loaded, you can figure out how to weigh the amount on the tags Might have to pay extra but you will know.
