How cold to leave running ?
Discussion in 'Experienced Truckers' Advice' started by Cat sdp, Dec 28, 2017.
  1. Cat sdp
    Cat sdp . .
    21,303
    76,193
    Apr 8, 2012
    Orion's Belt
    With the polar vortex upon us how cold does it have to get for you not to shut off your truck for anything........?
    My personal line is -15F . At that temp she runs period. All night/day whatever...
    Added fuel treatment (double dose) and hit the air system twice with alcohol ...
    Oxbow Thanks this.
  3. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    How do you add alcohol to air system on the truck?
  4. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    I set my barrier at about minus 10 depending on the wind .
  5. Cat sdp
    Cat sdp . .
    21,303
    76,193
    Apr 8, 2012
    Orion's Belt
    Couple of ways....
    Pull main supply line off compressor and dump it in there . It’s not great for your air drier cartridge but it beats a frozen line...
    Also I dump some in the tank directly. ...
    And finally fill the glad hand lines for the trailer....
    Tall Mike, hunts2much, Grubby and 3 others Thank this.
  6. Ridgeline
    22,720
    123,316
    Why do you guys use the weather channel term - polar vortex?
    It is an arctic blast. :)
    The wind doesn't really matter, the temps on the truck won't drop beyond -10 if the air temps are -10.
    By the way, I ask to keep the trucks running when it hits 10 degrees, hi-idle and not put on defrosters, just plain heat with no air on.
    Grubby, Lepton1, Feedman and 2 others Thank this.
  7. bzinger
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    That wind part depends on how well the apu is going to keep up .
    My engine with be warm regardless ...but I'm not gonna be cold lol
  8. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    I'd say depends if you have treated fuel. I caught hell the other day when my reefer gelled the fuel. Forgot last time I filled it was with Georgia fuel. Even though it was running nonstop it froze up at -1 in Wisconsin. That was a $283 bill at transport refrigeration.
    Hammer166, Grubby, Feedman and 2 others Thank this.
  9. Cat sdp
    Cat sdp . .
    21,303
    76,193
    Apr 8, 2012
    Orion's Belt
    I’m guessing reefers don’t return any fuel to the tank......?
  10. Oldironfan
    5,776
    5,544
    May 22, 2017
    Not much at all. 1/4 in line I think.
    Cat sdp Thanks this.
  11. bzinger
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    They return a little but not much ...anything below 10 mine goes to continuous and always on continuous overnight when cold .
    Never had a problem but most of my fuel is bought in northern states .
    TallJoe, Grubby, Broke Down 69 and 2 others Thank this.
