How make 09 reefer CA compliant?
Discussion in 'Refrigerated Trucking Forum' started by VegasBob, Jan 16, 2024.
  1. VegasBob
    VegasBob Bobtail Member
    6
    4
    Jan 16, 2024
    Is there a way to modify an 09 reefer to become CA compliant?
    austinmike Thanks this.
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Yeah but it requires replacing the TRU unit for a compliant one on your Reefer trailer.
    There's used ones available that aren't terrible expensive
  4. VegasBob
    6
    4
    Jan 16, 2024
    Ok thanks. Ever hear of an Evergreen muffler attachment? Supposed to go onto or replace the muffler? I never have and can't find any info on such a thing....
  5. REO6205
    REO6205 Road Train Member
    13,172
    60,487
    Feb 15, 2014
    California.
    Before you lay down any dollars check it with CARB first. The same with "new" units. The fast buck boys are waking up to a new market and there's a lot of false claims out there.
  6. boneebone
    boneebone Road Train Member
    2,295
    2,366
    Mar 13, 2009
    The only way to upgrade an older reefer unit is to replace the unit with either a ThermoKing S600 or S700 Precedent, which are CARB Compliant forever.
    You can also purchase a used Carrier X4 7300, 7500 or 8500 or 8600 Vector (which are CARB Compliant for seven years after manufacture), or you can purchase a Carrier EES kit (Engine Emission System) (which is a approved Tier 3+ Diesel Exhaust Filter) for it for about $9k, and it will extend the initial seven years compliance to be compliant forever.
    You can also purchase the Carrier’s newest model, the X4 7700 for $32k installed, which are compliant forever.
    Sully92 and catdog45 Thank this.
  7. VegasBob
    6
    4
    Jan 16, 2024
    Thanks for the reply's, helps a ton.
    boneebone and catdog45 Thank this.
