how to keep butt from hurting while driving?
Discussion in 'Experienced Truckers' Advice' started by bowman316, Oct 15, 2014.
  1. bowman316
    bowman316 Medium Load Member
    416
    70
    Dec 3, 2010
    aberdeen, md
    I got out of trucking for a few years, and started back up this feb. so now, after 8 months of so, my back side is just getting sore after all that sitting. After to hours in the seat, I can barley stand to sit on it anymore. I sit on a memory foam pillow sometimes, but that doesnt help much. maybe I should try those wooden mats I see? im 200 lbs right now, put on maybe 10 to 20 lbs.
    Shaggy Thanks this.
  3. woodlandman81
    woodlandman81 Bobtail Member
    11
    Jun 30, 2014
    have u thought of doing yoga in ur down time i know silly but i have a bad back and that seems to help idk if it will for a sore bum but worth a try
  4. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    Take your wallet out
    misterG, Aminal, unloader and 3 others Thank this.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Try getting out on the 30min. break and work up a sweat moving around truck as much as you can till you cant go any longer.
  6. MidwestResident
    MidwestResident Road Train Member
    4,325
    4,786
    Sep 20, 2012
    Wichita KS
    In addition to taking your wallet out of your back pocket, make sure that NOTHING is in your back pockets when seated in the driver's seat.
    allniter and Lepton1 Thank this.
  7. Sustanon
    Sustanon Light Load Member
    220
    155
    Dec 19, 2010
    KY
    buy airhowk seat,i got mine from amazone,its around 80$ the truck driver one,huge help
    tsavory and OPUS 7 Thank this.
  8. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    I nearly had to quit trucking last year from symptoms like the OP's. It was difficult to climb in or out of the truck. The bone in my left hip and down through my left leg was extremely sore. I tried memory foam and other seat cushions. Finally I tried a Magic Gel cushion and customized it and then it took a few months but the pain went away.
    If you start getting pain like this don't fool around and try to tough it out. Figure out a solution quickly.
    Even after getting the Magic Gel cushion I still had to figure out a better sitting position. Now I have the seat low and tilted forward for maximum circulation in my legs and have the back upright with maximum lumbar support in the air on my seat. I'm bolt upright as I drive with the steering wheel close enough to let my arms hang down. I'm more alert and relaxed and can drive much longer shifts.
    Surfer Joe, Skydivedavec and OPUS 7 Thank this.
  9. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Yup, we make too much money and it just hurt our back carrying it.
    Pool6710, OPUS 7 and Aminal Thank this.
  10. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    I get in and out enough in the course of a day that I don't run into a lot of this (a long drive for me is 90 minutes). The wallet, however, is a biggie. Even a small slim wallet will tilt the base of your spine sideways. A long day of less than perfect roads, and that little tilt to your spine really turns into a problem. That, and the pressure of the front edge of the seat on the back of your legs.
    bullhaulerswife Thanks this.
  11. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Let me guess op....
    International Towstar?
    Yuck.... Worst four weeks driving a truck ever. Junky AND uncomfy.
