How to Prime S60 12.7
Discussion in 'Experienced Truckers' Advice' started by RepoweredRookie, Jul 20, 2024.
  1. RepoweredRookie
    RepoweredRookie Light Load Member
    164
    137
    Apr 16, 2019
    Hey guys, hoping you can tell me how to get a 1999 Freightliner Century S60 12.7 primed.
    I’ve been having ground issues. Well truck started losing power, and then no power. I took off fuel filters - 1 was half full, the other 1 totally empty. Put new filters on, filled to the top with diesel. Now I can’t figure out how to prime.
    I see a valve in the middle of the truck, before the return enters the fuel tank, I assume that’s the fuel return.
    Any help would be much appreciated.
    blairandgretchen Thanks this.
  3. DUNE-T
    DUNE-T Road Train Member
    7,083
    17,262
    May 10, 2015
    Detroit, MI
    I blew shop air in the fuel tanks
  4. blairandgretchen
    14,031
    77,497
    Dec 9, 2011
    South west Missouri
    Yup.
  5. blairandgretchen
    14,031
    77,497
    Dec 9, 2011
    South west Missouri
    For next time - at least on mine, there’s a 90 degree shut off valve at the primary filter at the front of the engine, drivers side. I shut it off before changing filters.
    And remember to turn it after replacing filters.
    If your filter housing don’t have one - install it, or you’ll be doing the same dance again.
    There’s an air rig that will prime it, but like said, pressurize the tank with air to prime should work too.
    RepoweredRookie Thanks this.
  6. RepoweredRookie
    164
    137
    Apr 16, 2019
    So I had a mobile mechanic come out to help me get the system primed. He used 2 big cans of starter fluid and I thought the truck was going to blow up, but we did get it running.
    Did you guys make a cap with an air fitting and use 100 psi air?
  7. AModelCat
    166,469
    Never could wrap my head around how blowing air in the tanks could actually work. Your fuel system is essentially a loop - line from tank to the pump and then the head, line back to the tank.
    Pascal's law says that pressure applied to an enclosed fluid will be transmitted equally in all directions at every point. Pressurizing the fuel tank would give you an exactly equal backpressure up the return line. Would those two pressure not just cancel each other out and put you back to square one?
    Personally I have never had success trying it.
  8. Big Road Skateboard
    7,461
    42,542
    May 2, 2021
    I don't really like ether, and have never really used air myself. Most fuel systems have a check valve in the return, so there's that.
    60's just start so dang easy though. I mean, even ones i've built don't get over two cranking sessions before starting.
    No matter, shouldn't have taken 2 cans of ether either. Probably sucking air somewhere
  9. AModelCat
    166,469
    I hate ether too, I'll only use it if its winter and the engine's making smoke. 90% of what I work on have glow plugs or a grid heater so ether's a no-no anyways.
    I'd be curious as to how the check valves affect the system when you pressure it up with air. I would think that the back pressure on them would keep the fuel from flowing but who knows?
  10. Big Road Skateboard
    7,461
    42,542
    May 2, 2021
    Not sure since they're meant to stop fuel returning from the head. I think a 60 check valve closes at 3psi.
    And you'd have to plug tank vents
  11. Sons Hero
    Sons Hero Road Train Member
    3,518
    37,074
    Jan 8, 2021
    Indiana
    Crack an injector line off, air gets your fuel to the top end without any bubbles getting stuck. Thats what we’ve always done anyway. Fuel starts coming out the injector line, crank it tight, and she’ll fire.
