How to secure paper rolls to satisfy DOT?
Discussion in 'Experienced Truckers' Advice' started by MrsWJAA, May 14, 2023.
  1. MrsWJAA
    MrsWJAA Light Load Member
    60
    65
    May 2, 2015
    North Carolina
    I have been hauling these for over a year with zero shifts, the only securement is the non slip mats, gravity, and not driving like an idiot....
    However, blitz is coming up with cargo securement at the top of the checks so I figured I would ask what I should throw in there for window decoration if the DOT decides to cut my seal?
    I have load bars and e-track straps available.
    Thanks
  3. MrsWJAA
    60
    65
    May 2, 2015
    North Carolina
    The pic seems not to have posted, so here it is
    Rideandrepair Thanks this.
  4. trips74
    trips74 Medium Load Member
    367
    217
    Nov 7, 2007
    chicagoland, il
    If trailer is sealed they ain't getting in to see it. Typically if they target something like securements it's gonna be on flatbeds something easily spotted. Rarely do they check inside for load securement. And never sweat this dumb blitz, in 20 years I e never been inspected during it
    mitmaks, tscottme, bzinger and 4 others Thank this.
  5. MrsWJAA
    60
    65
    May 2, 2015
    North Carolina
    Good to know. The higher ups made it sound dire and told us to be prepared to have our seals cut... appreciate the insight
  6. Rideandrepair
    17,576
    56,940
    Aug 8, 2015
    What do the higher ups suggest to hold the paper rolls? There’s no securement that will hold them. It’s impossible. The sheer weight is the only thing holding them. They won’t move. If there’s an accident that can move them, no securement is going to help. From what I understand there are basically no securement rules at all for Dry Van. They bounced it around for about 5 years. About 20 years ago made a final rule stating that the walls are sufficient securement. Basic common sense applies here. A strap or two in front of a high pallet, maybe a strap or two on the back of the Load for certain items. Personal preference to avoid a claim is the main thing. I’m pretty sure there is no rule, unless something has changed. You can look it up on fmcsa website, Maybe print off, download, or screen shot a copy of the “final rule” along with a copy of “interpretation “ carefully and politely educate the DOT if needed. Lol.
    RubyEagle, JolliRoger, Siinman and 3 others Thank this.
  7. Numb
    Numb Crusty Curmudgeon
    4,349
    10,334
    Jan 30, 2012
    Charlotte, N.Carolina
    those big rolls weigh about 7K-8K a piece. you can't strap to wall the walls will cave in, don't ask how I know. :rolleyes:
    I've a hauled crap load of them for hundreds of miles.
    they are dangerous!
    drive like a tanker, no sudden stops, no hard cornering.
    gravity mats is it.
    tscottme, Bean Jr., MrsWJAA and 2 others Thank this.
  8. Long FLD
    Long FLD Road Train Member
    12,958
    54,388
    Mar 4, 2015
    If they want to they can cut the seal and give you a form saying why the seal was cut as well as signing off on the new seal they put on.
  9. kemosabi49
    10,992
    47,974
    Jan 13, 2013
    SW Arkansas
    I had Texas cut the seal on my dry van when I was with Landstar. Said he was checking for securement. Trailer had come across from Mexico through Laredo so he was probably checking for dope or illegals. Got up into the trailer and climbed up on the freight and went all the way to the front. Then he resealed the trailer and took off.
  10. trips74
    367
    217
    Nov 7, 2007
    chicagoland, il
    The hire ups sit behind a desk and have probably never been to a dot scale or inside a truck, hire ups can well you know
    Cattleman84, tscottme and MrsWJAA Thank this.
  11. mud23609
    mud23609 Medium Load Member
    652
    1,444
    Mar 9, 2015
    Put a couple of straps across from e-track to e-track. Sure, it's lipstick on a pig. No doubt about it. However, it only takes two minutes, and in the unlikely event they do happen to cut the seal, it looks better to the officer.
    Looking like you pay attention to small details is almost as important as actually paying attention to the small details. In the end, if it looks good at a quick glance, they sometimes figure you have your stuff together and don't look too deep.
    Cattleman84, rockeee, Siinman and 5 others Thank this.
